RG 570 Tremblock setting
04-21-2005, 05:02 AM
knotty
Posts: 31 - iTrader: (
when setting the tremblock it says in the manual that the block should be parrallel with the body. What part should be parrallel? I have the FLoydd Rose block and it appearrs to be leaning towards the fingerboard but the actual blocks retaining the strings are parrallel to the body. There are lots of angles on the block so just saying parrallel is a bit confusing. It is to a newbie like me anyway.
Any advice guys?
knotty
Find all posts by knotty
04-21-2005, 07:11 AM
dex
Posts: 1,972 - iTrader: (
Re: RG 570 Tremblock setting
The
trem block
is the thing that holds the springs, the other thing is called
trem plate
Aslo if you look on the side of the trem plate you will see the Knife inserts - thry should be at 90 to the posts.
ilia
dex
Find all posts by dex
trem block
trem plate
what does zakk wylde have his amp setting to
heaviest triaxis setting?
when setting up effects pedals what is the order of the chain
what does the presence setting do on a guitar amp
how to get a korn setting
RG GOLD and RG METAL
cowcowcow
09:17 PM
DIfference of sound between rg 2550 - rg 2820
Pezi
04:21 AM
fully setting up an ibanez RG 7620.
kurts_heroin_buddy
Tech: Setup, Repairs and Mods
11:11 PM
Which RG is my guitar - I got a used rg and am unsure as to
slinger75
04:30 PM
Ibanez RG with hardtail? - high quality RG with no trem??
shask
11:16 PM
02:22 PM
