Old 06-13-2001, 03:09 PM
chilln2music  is offline
Posts: 264  -  iTrader: (1)
RG body vs. RG7 body - size difference?
hey guys...i was just wondering if there was a difference in the size of an RG 6 string body compared to an RG 7 body or is the neck cavity just bigger on the standard RG body. thanks.
Old 06-13-2001, 03:27 PM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
No size differences between RG &amp; RG7. They have pretty the same size.
Only the neck pocket is a little bigger.
I think it's great, cause I don't like big sized guitars.
nuno
Old 06-15-2001, 05:11 PM
ChrisReedSmith  is offline
Posts: 523  -  iTrader: (0)
I'd have to disagree and say the RG7 feels/looks like a much bigger guitar. Of course its about the same as JEM to UV is. Anyone have specs? if you know for sure that they are built the same size then I'll believe you but I swear the 7-strings seem much wider and bigger then JEMS and RG 6's.
Old 06-15-2001, 05:15 PM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
Same body and neck size, wider neck pocket and neck.
Only the new RG7 XLs have a slightly longer length due to 27" scale neck... glen
Old 06-15-2001, 06:53 PM
bammbamm  is offline
Then why doesn't my Rg-550 fit into my 7620 case? seems as if the upper horn is too long on the 550 top fit properly.
Bamm
Old 06-15-2001, 07:04 PM
jemsite  is offline
Administrator
Images: 11
the 7 has a longer headstock for the 7th machine head This is why the JEM cases were elonged an inch or so for the UV. Same body-to-nut measurements... glen
Old 10-20-2009, 07:22 PM
Crazy_Guitar  is offline
Posts: 1,319  -  iTrader: (0)
Reviews: 4
Re: RG body vs. RG7 body - size difference?
Still doesn't explain why a "smaller" 550 does not fit the "bigger" 7620 case!
Old 10-20-2009, 07:44 PM
Ironjose  is offline
Posts: 1,060  -  iTrader: (0)
i always wondered about this... since i am thinking about getting a rg1527 and the prestige case is just the same size...
gracias.
Old 10-21-2009, 02:28 AM
bluffalo  is offline
Posts: 73  -  iTrader: (0)
my rg550 and 7620 both fit perfectly into my ibanez fitted hardcase
Old 10-21-2009, 03:02 PM
jim777  is offline
Old 10-22-2009, 02:40 AM
Ayrton  is offline
8 years!
That has got to be a record of some kind.
