RG20th neck question
02-06-2007, 11:33 AM
Dazza1004
Posts: 265 - iTrader: (
Hi all,
How does the neck on the RG20th compare with the DBK in terms of thickness ?
Thanks
Dazza1004
Find all posts by Dazza1004
02-06-2007, 11:42 AM
bikeman
Posts: 660 - iTrader: (
Re: RG20th neck question
I think it'll be thinner - check the specs of the DBK versus the original Wizard.
bikeman
Find all posts by bikeman
02-06-2007, 11:52 AM
Dazza1004
That's what I thought, I am already thinking about selling my DBK because it's too thin. Shame
Thanks for the info
Dazza1004
02-06-2007, 12:29 PM
Dee
Posts: 8,514 - iTrader: (
17mm at 1st fret, same as the original 550 neck.
Wicked.
Dee
Find all posts by Dee
parker are they neck thru
how can i tell thin or standard neck prs
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
Jem7PBK - Question about the neck
Martijn
09:04 AM
Wizard II Neck Nut Replacement Question
Dark Alone
Tech: Setup, Repairs and Mods
10:22 AM
Painted neck? Sanded neck?
Drache713
Other 7-string Guitars
12:45 AM
Neck profiles question from an Ibanez newbie
Anonymous
09:26 AM
Different Jem's = Different Neck profiles? - a question rega
jem7vwh
04:14 PM
02:50 AM
