Re: Rg3s0dx neck swap
The JEM neck will probably cost more than your entire guitar did!
If you want to go with it, it should fit. Only thing you will most probably need to do is dowel the neck's existing holes to fill them, and redrill the neck holes to match the RG350s neck joint.
