Old 12-17-2008, 02:13 AM
da_ragin_ajun  is offline
Posts: 4  -  iTrader: (0)
RG550 1987 and RG550 20th: do they have the same pickguard?
I'm buying a matching pickguard and truss rod cover for my rg 550 20th, but the maker pointed out that they might have different screw layouts/shapes/knob holes.
I recall reading that the volume knob is slightly further away. Is this true? Any other different spacing? If anyone with both guitars could provide some input that would be great! Thanks.
Old 12-17-2008, 07:53 PM
ketiov  is offline
Posts: 28  -  iTrader: (0)
Re: RG550 1987 and RG550 20th: do they have the same pickguard?
All that matters are the holes for the screws to mount it to the body. I doubt that the volume knob being slightly further away will cause any trouble, as from what I remember from my 550, there is a lot of room for all the controls.
Old 12-17-2008, 08:25 PM
Hmm, I see. that's not definitive but thanks. Has anyone actually replaced the pickguard on a RG550 20th?
Old 12-17-2008, 08:34 PM
D.Vial  is offline
Posts: 221  -  iTrader: (0)
No, the 87' 550 had on a different position the volume knob
Old 12-17-2008, 08:49 PM
Ayrton  is offline
Ibanez moved the volume knob because the tremolo bar would hit it on dives.
Old 12-17-2008, 09:50 PM
Ahh okay, so that is true. I guess I'll just have to drill that out myself.
Are the screw locations/holes the same?
Old 12-21-2008, 12:55 PM
iced_ink  is offline
Posts: 66  -  iTrader: (2)
If i were you i'd have the screw holes left blank and be drilled(by you) to the same spot as your old pickguard.even original pickguards' screw holes from ibanez don't exactly line up on their own guitars-RG to RG,jem etc. vice versa.
550, pickguard
FS: RG550 (1987?) ModernGuitarist Classified Ads: Guitars and Gear 12 05-06-2008 03:54 PM
Ibanez RG550 1987 Pickguard Ambitot Pu Phang Other Ibanez Guitars (including Premiums) 3 08-21-2007 11:08 AM
WTT:1987 Rg550 Dy guitarsnguns04 Classified Ads: Guitars and Gear 25 08-21-2006 01:09 PM
Fs: 1987 Rg550 Dy! toddmiro Classified Ads: Guitars and Gear 5 06-22-2006 02:20 PM
1987 Rg550- Dy jemaholic Classified Ads: Guitars and Gear 6 08-25-2005 09:02 AM
