I am at work right now so I will post pics tonight when I get home. I got a stock moses neck and had a machinist named Phil Langley cut the slot for the LSR roller nut. I installed the neck, tuners and nut myself. On my other S470 I actually shaped the heel to the AANJ shape. It turned out pretty nice, I do need to touch it up with some gel coat but again this is purely cosmetic. I also reshaped the headstock as you will see when I post pics. I can't tell you how well these guitars stay in tune with the LSR rollernut, steinberger locking tuners and ZR trem installed, and I don't have to use the fine tuners at all. All tuning is done with the steinberger tuners. Also I don't know that there is a big difference between the two heel shapes with regards to the access of the higher frets, they both work fine. I will post pics tonight.
Monte
