Old 08-15-2009, 06:58 PM
IBNZ_RG  is offline
Posts: 543  -  iTrader: (0)
Reviews: 18
Square heel help?
I just recently got an rg550r neck from evilbay for my '93 rg470 body. as soon as I got the neck I slapped it on. Every thing was perfect except for the neck joint. The neck heel seems to thin or the bodys joint is too wide. Do you think this is because of the age difference? Or because the neck was on a tilt joint and the body isn't a tilt joint? Will this affect playing? And I'm positive it's not fake because it has gotoh tuners.
Old 08-15-2009, 07:26 PM
IBNZ_RG  is offline
Reviews: 18
Re: Square heel help?
lighter part is the joint on body
non-tilt joint
not sure if you can see the gap
Old 08-15-2009, 11:00 PM
littlephil  is offline
Posts: 422  -  iTrader: (0)
It wont be because of the tilt joint. It might be because of age, but probably not. They are both machine made, so you wont get a perfectly tight joint.
You can tighten it up a bit by placing a thin bit of card/paper on either side of the neck pocket, to keep it tight and straight while you tighten the neck screws. Get the neck screws fairly tight and it should be fine.
WTB: jem body w/ old square heel hiesenberg Classified Ads: Ibanez JEM/UV Guitars 5 01-19-2009 12:09 AM
WTB: Square heel RG neck TequilaKing Classified Ads: Guitars and Gear 0 11-22-2008 02:58 AM
AANJ or square heel Toce Other Ibanez Guitars (including Premiums) 27 05-31-2008 04:24 PM
WTB Square heel Jem neck DJR Classified Ads: Ibanez JEM/UV Guitars 0 12-30-2007 07:28 AM
Square heel to AANJ? jono Tech: Setup, Repairs and Mods 2 05-14-2002 06:50 PM
