String Spacing
05-21-2007, 04:46 PM
Devon8822
Posts: 389 - iTrader: (
String Spacing
I have noticed that when I have played various Ibanez axes before that the string spacing is alot wider on them than other guitars. What is the spacing measurement? and why is it wider than other guitars, what purpose is it for? Is it supposed to make it easier to play or what? thanks
Devon8822
Find all posts by Devon8822
05-22-2007, 11:10 AM
Devon8822
Re: String Spacing
anyone?
Devon8822
05-22-2007, 11:30 AM
nuno
Posts: 4,725 - iTrader: (
Re: String Spacing
RGs are usually wider at the nut: 43mm instead of usual 42mm. the spacing at the bridge is pretty much the same as on Fenders, which is a bit wider than on Gibsons. with exceptions, of course...
don't know why RGs are wider at the nut, yeah, probably to make'em easier to play, i guess.
nuno
Visit nuno's homepage!
Find all posts by nuno
05-22-2007, 08:58 PM
Ki swordsman
Posts: 1,273 - iTrader: (
Re: String Spacing
personally i'll never go back to 42mm ever again... EVER!
Ki swordsman
Find all posts by Ki swordsman
05-23-2007, 12:07 AM
TommyGuitar
Posts: 206 - iTrader: (
Re: String Spacing
Can you really tell the difference? It's a mm. Maybe I'm just a caveman?
TommyGuitar
Find all posts by TommyGuitar
05-23-2007, 12:21 AM
Ki swordsman
Re: String Spacing
it's a massive(!!) difference to me, most noticably on chords played near the nut
Ki swordsman
05-23-2007, 04:28 AM
nuno
Re: String Spacing
as little as it can be, 1mm is a huge difference. just try it.
nuno
05-23-2007, 11:11 AM
bobby simcox
Posts: 163 - iTrader: (
Re: String Spacing
my guitars(Zachary) have a 46mm wide nut!!! Classical guitar string spacing!!! The idea behind it is so that it minimizes unwanted string muting and cramping!!! It actually Does minimize the unwanted muting, but i've never had a problem w/ cramping, so i don't know about that!!!
bobby simcox
Find all posts by bobby simcox
05-23-2007, 01:25 PM
richard1973
Posts: 957 - iTrader: (
Reviews: 10
Re: String Spacing
it's designed like that just to purely annoy, my RG is wider than my other two ibanez's, its also a thicker neck too. Though you do get used to it to a point it doesn't really matter and your fingers adapt between the guitars. But at first it 's annoying, especially when picking chords where you are
string skipping
richard1973
Visit richard1973's homepage!
Find all posts by richard1973
05-24-2007, 09:33 AM
Devon8822
Re: String Spacing
What guitars have 43 and which have 42? I checked some sites and most have 43... can some one give me some example of companies that use 42 width?
Devon8822
05-24-2007, 09:38 AM
CaptainOi
Posts: 135 - iTrader: (
Re: String Spacing
Parker use 42mm width....and there are sweet
http://www.parkerguitars.com/code/mo...s_fly_mojo.asp
love the fly's
CaptainOi
Find all posts by CaptainOi
05-24-2007, 11:34 AM
S-man
Posts: 1,757 - iTrader: (
Re: String Spacing
Ki swordsman
Very true.
S-man
Find all posts by S-man
05-24-2007, 11:56 AM
markg5150
Posts: 2,361 - iTrader: (
Re: String Spacing
My RG20th is 43mm and my Suhr is 42mm and surprisingly the difference is really noticable, the shape of the neck probably influences why it feels different too.
markg5150
Find all posts by markg5150
05-24-2007, 02:27 PM
stratoskier
Posts: 769 - iTrader: (
Re: String Spacing
For
Ibanez necks
, the Vipers, JS, Radius, early SA's and certain others are all 42mm. Some other models are actually 41mm -- that includes the 97-98 Blazer reissues, some of the Talmans, the AT (?) and maybe others. Basically anything that's going for a strat-like vibe is likely to be 42mm or less.
Bert
stratoskier
Find all posts by stratoskier
ibanez neck
ibanez necks
string skipping
edge pro f spacing?
where to buy guitar string sin southampton
what distortion pedal can take guitars string 10-60
use a .016 for the 2nd string?
jpx 7 string?
Major Help! String Clamp Won't Budge!
Rekuss
Tech: Setup, Repairs and Mods
07:57 PM
other guitar forums
SandmaN211
Off-topic / Miscellaneous
38
12-27-2006
12:31 AM
Yet another poorly mixed song by your truly
IbanezroadstarII
33
03-16-2006
10:01 PM
rg1527 seven string question
Jebus
06:38 AM
Picking up the slack... - ...on that low string
mechanyx
02:23 AM
08:56 PM
