Old 05-19-2002, 08:45 AM
Kev Brigden  is offline
Posts: 496  -  iTrader: (0)
The Edge hump and how it affects size...
I've looked through the Trem section in the Guitar area of the site. I've been told to do this repeatedly, I still cant find it... what are the actual differences SIZE wise???
Is the Edge shorter in length because it has a higher profile and hasnt been 'squashed' out or is it basically the same shape and size as the lo-pro but just high profile??? As a matter of interest, which would one have MORE luck retrofitting... if it is smaller I assume it would be the edge?!
Please dont close this straight away and please excuse my ignorance if there is a topic that refers to this but I honestly cannot find it...
cheers Kevin
Old 05-19-2002, 11:00 AM
Polaris20  is offline
Posts: 1,418  -  iTrader: (0)
Re: The Edge hump and how it affects size...
cheers Kevin
what are you trying to retrofit it to?
As a side note, ladies always told me size doesn't matter )
Old 05-19-2002, 11:30 AM
EKG  is offline
Posts: 2,280  -  iTrader: (0)
Here is what I get:
Edge base is 2.64 in [66.9 mm]
Lo-Pro base is 2.77 in [70.4 mm]
HOWEVER, the OVERALL length is longer on the EDGE due to the string lock screws. The Lo-Pro would actually take a smaller route.
For complete diagrams, see Edge and Lo-Pro, coutesy of Rich, Ibanez Rules!!
Edit: corrected links
Old 05-19-2002, 03:52 PM
Cheers for the info EDDIE!!! yet again you come to my aid !!!
kevin
Old 05-20-2002, 08:52 AM
earthman  is offline
Posts: 223  -  iTrader: (1)
is it still the case that there are different trem-block lengths on different edges from different guitars?
I know the radius used to use a different block to the RG/Jems, and I think there was a third size too...
--c.
Old 05-20-2002, 01:31 PM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
we gotta get back in time, when Edges weren't recessed yet, and when the Radius, the Saber and a few others, had just a slightly recessed cavity, not as deep as they are since early '90s...
string lock
