Old 09-07-2008, 07:46 AM
steini  is offline
Posts: 5  -  iTrader: (0)
tremolo system from rg 770
hi, i own a rg 770, and since a few weeks i got problems to keep the guitar in tune after using the tremolo. (of course i add new strings :-)) i tried to fix this problem with a blackbox, but its still remains, so i kicked off the blackbox. has anyone a guess, or face the same probs? thx steini
Old 09-07-2008, 08:10 AM
Lordiesel  is offline
Posts: 448  -  iTrader: (1)
Images: 1
Re: tremolo system from rg 770
i'd suggest the ibanezrules.com setup guide. Should fix any tuning issues you have.
Old 09-07-2008, 10:00 AM
callen3615  is offline
Posts: 1,412  -  iTrader: (7)
you could have worn knife edges. how old is the tremolo?
Old 09-07-2008, 10:15 AM
steini  is offline
i bought it used, its a 92 model, i think, its the original one...
Old 09-07-2008, 11:37 AM
Rich  is offline
http://www.ibanezrules.com/tech/setu..._stability.htm
Old 09-11-2008, 01:02 PM
steini  is offline
Hi everybody,
thx for your links to solve my tuning probs, but i found out following, which i have no explanation: when i lay the rg on the table (flat) and start tuning, it keeps in tune. as soon as i take the rg in the playing position, the tuning goes flat, i do not touch the strings or the arm. has anybody an idea? thx steini
Old 09-11-2008, 01:18 PM
Riverdragon  is offline
Posts: 324  -  iTrader: (3)
Have you checked if the neck is tight in the joint?
Old 09-11-2008, 02:10 PM
Rich  is offline
Ever hear of a thing called gravity?
Never tune in anything other than playing position.
Old 09-12-2008, 05:47 AM
560licious  is offline
Posts: 322  -  iTrader: (0)
Images: 4
yep. gravity is playing with your floating tremelo.
tuning probs
PRS tremolo vs. Floyd Rose pro tremolo bjamin86 Tech: Setup, Repairs and Mods 5 01-25-2010 10:27 AM
tremolo system for my RG320? bjamin86 Other Ibanez Guitars (including Premiums) 2 05-22-2006 12:59 AM
D TUNA EVH will it work on original Edge tremolo system mattpj Other Ibanez Guitars (including Premiums) 2 01-21-2004 02:35 PM
