Re: Using Edge III anchors and studs for Edge pro?
I believe the anchors are different, you will need to drill a different hole for them. If your body is already predrilled, you'll have to enlarge the holes for the slightly larger 2le2b studs. Rich can tell you the correct size.
If your body is undrilled, then you'll just drill the correct size straight away. They're well worth it whichever route you choose because the 2le2bs are that much better than edge 3 inserts.
