Old 05-19-2006, 07:48 AM
pera_a777  is offline
Posts: 406  -  iTrader: (0)
What gauge of 7 string set for a 6 string?
I have a rg550..with lo pro..
i wanna tighten my sound by putting uper 6 strings of a 7 string set..
So, which gauge 7 strings set should i use, so that tension with tuning in H would be aproximatly the same as with 9s in regular E tuning..?
..so i have less to fiddle with the setup..would the 10s 7 string set (which is available to me at the moment) be fine for this, or too thick maybe?maybe the 9s 7 string would be better..?
any experiences..?
Thannk you very much!
Old 05-19-2006, 09:41 AM
Roland  is offline
Posts: 617  -  iTrader: (0)
Re: What gauge of 7 string set for a 6 string?
You mean the six lower strings of a seven-string set?
Try Skull Strings. They´re designed to be detuned, and an acquaintance of mine says they´re good. I haven´t tried them, though.
However, if you´re tuning to B, I suggest you should go with gauges 13-17-26-36-46-60. I´d recommend GHS Boomers, or D´Addarios.
Old 05-19-2006, 10:05 AM
Yeah..i mean exactly that..so, the gauge you reccomand is actually 10s 7 string set, right..isnt it to thick...do you have any experience, or anyone else, since i am trying to get the 9s on regular tuning tension..
i am sure many of you guys were doing this..please give me some input..?
thanx
Old 05-19-2006, 10:15 AM
Angelo Guitars  is offline
Posts: 295  -  iTrader: (0)
If you want to just tighten up the E, A, D strings, then use .009 - .046.
If you want to tighten everything up, then .010 - .046 set should be good enough. You will have to make a slight adjustment.
Old 05-19-2006, 11:30 AM
Roland  is offline
Personally, I like 10s a lot. You could go with 9s on the top 3 strings, but I HIGHLY recommend 36-46-60 on the bottom three.
Old 05-19-2006, 11:36 AM
Ok, roland..thanx for your oppinnion..anyone out there..?
Old 05-19-2006, 01:42 PM
jim777  is offline
Ernie Ball makes strings called "Not Even Slinky" that Petrucci uses when he tunes dow to C for songs like "As I Am". I'd check those as well.
ernie ball, lower strings
7 String gauge question.... nosferatu123 Other 7-string Guitars 31 03-19-2011 02:01 PM
Yet another poorly mixed song by your truly IbanezroadstarII Multimedia: Music, Pictures & Sounds 33 03-16-2006 10:01 PM
Changing string gauge questions ZenekZelman Tech: Setup, Repairs and Mods 4 10-24-2005 02:45 AM
what do you think .009-.042 with a low .058 string gauge JN777 Other 7-string Guitars 0 01-15-2005 11:31 AM
7th string Gauge JN777 Other 7-string Guitars 13 02-21-2004 07:54 PM
