Whats wrong with my RG?
02-18-2007, 03:34 PM
wixomwhat
Posts: 238 - iTrader: (
My 770 goes out of tune every time I play it.
I tuned it up today and all the strings were out of tune within 5 mins and I wasent using the
trem arm
at all.
This is the only floyd' guitar I have trouble with all the rest of them stay in tune fine.
any ideas?
wixomwhat
Find all posts by wixomwhat
02-18-2007, 03:38 PM
crevis
Posts: 2,599 - iTrader: (
Re: Whats wrong with my RG?
More info please.
crevis
Find all posts by crevis
02-18-2007, 03:42 PM
andy7jem
Posts: 6,504 - iTrader: (
Are they new strings,old strings??
andy7jem
Find all posts by andy7jem
02-18-2007, 03:49 PM
wixomwhat
the strings arent to old.
edge trem
is set up correctly.
wixomwhat
02-18-2007, 06:34 PM
MF_Kitten
Posts: 219 - iTrader: (
it could be the temperature in your room, it could be the neck... i dunno really... check the intonation and the neck for bowing...
MF_Kitten
Find all posts by MF_Kitten
02-18-2007, 07:23 PM
70Seven
Posts: 204 - iTrader: (
Have a tech look at it and do a set up. Once its done just keep the same string gauge on it and it should be fine. Did you always use the same string gauge and tuning?
70Seven
Find all posts by 70Seven
02-18-2007, 07:40 PM
brianxtr
Posts: 1,642 - iTrader: (
look very good to it....it could be so much....it could be the spring set up after other strings.neck damage?
neck screws
?toplocks open??try look ask a friend who's good with trems.....good luck...tell us what it was....
brianxtr
Find all posts by brianxtr
02-18-2007, 08:36 PM
David McCarroll
Posts: 2,049 - iTrader: (
Check the two bolts that hold the
locking nut
on the neck, check the screws that hold the tuners on the neck - heck, check the screws that hold the neck on the body - if any of them are loose, you have a potential tuning issue.
David McCarroll
Find all posts by David McCarroll
02-18-2007, 09:14 PM
waylay00
Posts: 3,763 - iTrader: (
When exactly does it go out of tune?
waylay00
Find all posts by waylay00
02-18-2007, 09:15 PM
TommyGuitar
Posts: 206 - iTrader: (
I'm not sure if a bowed neck will have anything to do with tuning problems.
TommyGuitar
Find all posts by TommyGuitar
02-18-2007, 10:46 PM
wixomwhat
waylay00
within 5 mins.
wixomwhat
02-18-2007, 10:50 PM
wixomwhat
I just got some new strings to put on it and I've got a few things I'm gonna try. The 3 springs i'm using are also new so that shouldn't be the problem.
I think the "pressure pads" might be the problem. 2 of them are the original pads which makes them 17 years old.
wixomwhat
02-19-2007, 12:22 AM
Kii
Posts: 130 - iTrader: (
Did you stretch the strings?
Kii
Find all posts by Kii
02-19-2007, 01:42 AM
TommyGuitar
Yeah, stretch your strings.
TommyGuitar
02-19-2007, 03:38 AM
Shredder87
Posts: 417 - iTrader: (
I noticed that you mentioned that you had new springs... there's a potential issue there. New springs will need to be broken in... until they settle you may get tuning issues.
I also think that you should check everything that has been mentioned above... guitars with double-locking systems are a minefield, could be anything wrong.
Cheers
'87
Shredder87
Visit Shredder87's homepage!
Find all posts by Shredder87
edge trem
ibanez trem
ibanez tremolo
locking nut
neck screws
trem arm
guitar rusty cooley whats maney
"What's wrong with PRS guitars"
whats is ibanez 2010 line up?
whats a floyd rose?
whats steve vais dna guitar
RG 1570 vs. RG 2550EX
fox
06:13 AM
Ibanez RG 560-----my experience
lifeson
Comments to Ibanez
08:40 AM
RG 550 or RG 750 - Is one any better than the other?
jl9184
08:34 PM
RG VS. VB * - please help me guys
ChrisReedSmith
06:18 PM
Which RG is my guitar - I got a used rg and am unsure as to
slinger75
04:30 PM
06:24 AM
