Old 11-04-2006, 12:01 PM
beerman  is offline
Posts: 6  -  iTrader: (0)
Exclamation
wiring help rg1570 HS-2
hi
how to wire my ibanez rg1570 w/ HS-2 (mid)
i wanted to install HS-2 on middle.
which is the HOT wire?
and which goes to the ground?
was looking online seems confusing its either the RED or BLACK
dimarzio website has a totaly different 5 -way switch.
anyone installed a HS-2 , say on a rg570 or similar H-S-H
w/stock 5 way switch.
Old 11-04-2006, 12:13 PM
crevis  is offline
Posts: 2,599  -  iTrader: (1)
Re: wiring help rg1570 HS-2
You'll have to get a multi pole switch like the dimarzio one.
Old 11-04-2006, 01:21 PM
Awakened Sleeper  is offline
Posts: 203  -  iTrader: (2)
This page might be of some use. You'll see they have a list of colour-codes amongst MANY other things.
pole switch
Ibanez jem alternate stock wiring method??! Ki swordsman Pickups & wiring 7 11-24-2005 07:31 PM
Fishy Js100/1000 wiring Zeppel Pickups & wiring 3 02-20-2005 06:26 PM
Jem-Like wiring from two Humbuckers? MicJustMic Pickups & wiring 2 06-05-2003 09:26 PM
JEM10th Evolution Wiring Diagram..... gerca Pickups & wiring 6 11-18-2002 05:59 PM
Double Edge wiring diagram needed... - Changing pickups in S armadillo Tech: Setup, Repairs and Mods 6 03-07-2001 10:04 AM
