Old 05-02-2008, 06:38 PM
cjl5150  is offline
Posts: 146  -  iTrader: (1)
Wzard neck on an RG321 body
Will a Wizard neck from an RG570 fit on an RG321 body without any mods? Just curious, I'm thinking of taking on a project. Also, would a standard fixed Strat-style bridge fit on the RG321 body?
Thanks,
Chuck
Old 05-02-2008, 07:03 PM
Ayrton  is offline
Re: Wzard neck on an RG321 body
The 570 neck may be a bit thinner (width), but is should bolt up fine provided they have the same neck joint style (AANJ)
Old 05-02-2008, 07:35 PM
PrinceAlice  is offline
Posts: 69  -  iTrader: (0)
Reviews: 6
Tell us if it works.
Old 05-02-2008, 07:44 PM
Agent540  is online
Posts: 1,073  -  iTrader: (0)
nothing wrong with the locking nut ?
Old 05-02-2008, 08:12 PM
D.Vial  is offline
Posts: 221  -  iTrader: (0)
It won't work I've tried it.
Old 05-02-2008, 08:27 PM
cjl5150  is offline
So, the Wizard isn't a direct replacement for the Wizard II???
Old 05-02-2008, 08:29 PM
cjl5150  is offline
Was the neck that you used an AANJ?
Old 05-02-2008, 08:55 PM
D.Vial  is offline
Yes it was, in fact it was a Wizard II
Old 05-02-2008, 10:12 PM
albee1952  is offline
Posts: 784  -  iTrader: (2)
There may be a problem with the location of the screw holes. Any decent luthier could dowel and re-drill as needed.
Old 05-02-2008, 10:59 PM
cjl5150  is offline
Well, I just took the neck off of my favorite guitar, an RG570, and tried putting it on the 321 and that is the problem-the location of the the screw holes. The neck fits in the pocket just fine. I'm wondering if I do dowel and redrill-will the scale length be off and cause an intonation problem? FWIW the neck looks great on the body, it's one of the flame top, redburst ones. I really want a hardtail RG with a Wizard neck.
Old 05-02-2008, 11:01 PM
cjl5150  is offline
What kind of problems did you have?
Old 05-02-2008, 11:31 PM
Ayrton  is offline
Just drill new holes and dowel the old ones.
You will not have any scale problems, because both guitars are the same scale.
Old 05-03-2008, 12:08 AM
cjl5150  is offline
Good point. I was just thinking that the neck pocket seems to go further into the body on the 570 versus the 321.
Old 05-03-2008, 12:58 AM
Darin  is offline
Posts: 2,459  -  iTrader: (2)
Just measure from the bridge to the 12th fret and to the nut.
Old 05-03-2008, 10:25 PM
D.Vial  is offline
The Wizard II was from a tremolo-equipped guitar so it was a bit thinner (width) and a considerable space of the joint was left over from the left side.
equipped guitar, locking nut, neck joint, paf pro
Warped neck? Cracked body? help me out! Devon8822 Tech: Setup, Repairs and Mods 15 10-21-2007 06:26 PM
FS: AT300, RG7620VK body and neck ajdehoogh Classified Ads: Guitars and Gear 5 07-21-2007 08:55 PM
Check this out!!!!! ELicari JS (Satriani Model) Ibanez Guitars 73 08-28-2006 10:09 AM
Epihone neck on an Ibanez body? jonadam1975 Other Ibanez Guitars (including Premiums) 7 07-12-2005 04:08 PM
RG450DX Complete Body and Neck Parts TAorama Classified Ads: Guitars and Gear 6 06-19-2005 10:20 PM
