Old 03-07-2006, 08:17 PM
Chud  is offline
Posts: 926  -  iTrader: (0)
A very random guitar project...
Okay, so here's the basic idea guys:
What i want to do is get the most affordable double neck 6-string possible.
What do you reckon would be the best way about going to do this? I looked up the Warmoth custom route and that comes in at around £900 (way too much for a random fun project like this).
The other idea i had was to get a double-neck Epiphone SG and just use 6-string on both necks (would this work?)
Some of the things i want to do is to do include:
Top neck tunned to something different like Cadd9, Bottom neck tunned to Standard E. I'd also like to put a Floyd Rose onto the bottom neck. Would this be madness to do on the Epiphone SG?
Also, i'm thinking about putting Dimarzio X2N's into it or another high output pickup (EMG's seem a bit over the top plus X2N's and the similar go for cheaper and i prefer their tone) - mainly in the bridge position of both necks.
Main reason i'd want to do this is because i saw the double neck Ibanez S-series guitars (the 7/6 and the 12/6 string versions) and thought to myself how cool it would be to come onstage with a double necked 6-string sort of animal and just really scare people Only problem is - Those Ibanez doublenecks are bloody hard to come by! Sorry if this seems a bit mental, but i thought i'd be pretty cool
Any ideas on which would be the most "ecconomical" way of doing this crazy project? Any answers accepted (mad, serious whatever!)
Cheers,
C.
Old 03-08-2006, 12:20 AM
buddroyce  is offline
Re: A very random guitar project...
You can always buy two cheap @$$ guitars and then just chop them 3/4 of the way and join them.
Old 03-08-2006, 12:29 AM
elcid  is online
Posts: 8,720  -  iTrader: (12)
Buy an Epiphone double neck SG, new pickups and get it routed for a floyd rose, and let me know how much under 900 you come.
Old 03-08-2006, 06:17 AM
nickcoumbe  is offline
Posts: 2,417  -  iTrader: (0)
Reviews: 34
I think the only way to do it easily (if you can't buy the double bubble that you want) is to do as budd royce says and buy two 6 strings. You could probably get a body made , although cutting in half and gluing might work ok, and it would be cheaper. I would be prepared to give it a go, and I work in West Sussex, so I am sure we could work somethig out.
Old 03-08-2006, 12:20 PM
Hobophobic  is offline
Posts: 260  -  iTrader: (0)
There was a thread on another forum where somebody took two guitars, cut them and joined them to make a double. Seems like they had to cut a piece of wood to insert between the two cut bodies to get a usable spacing that still looked nice then did a little contouring by hand to make everything flow together nicely. Once it was refinished it actually looked quite nice. Now if I can just remember where I saw it I'll add the link...
Old 03-08-2006, 09:08 PM
Chud  is offline
Okay guys, taking the Warmoth route and taking the "Cheap and cheerful" route, i've managed to get it to around £600~ for this:
I've decided not to go down the Floyd Rose route, as that's so exspensive for a "fun" guitar + it'd be tunning hell
IMHO, this is alot cooler then buying a double neck SG... though bare in mind it is a rough bash on MSpaint
Old 03-08-2006, 09:41 PM
David McCarroll  is offline
Posts: 2,049  -  iTrader: (5)
2 Squier Strats and a table saw might be cheaper.....
Old 03-09-2006, 09:20 AM
Chud  is offline
Yeah that'd be one idea that i'm contemplating, but it seems a pain in the arse what with scratchplates and all. It'd probably come to the same price anyway
Old 03-09-2006, 09:30 AM
caprile  is offline
Posts: 1,619  -  iTrader: (6)
I have had this idea myself. My conclusion was to buy 2 Ibanez RG321's and have their body joined and refinished by a good luthier. (Well actually I thought of a 321 and a 7321 ...7/6!!!)
Old 03-09-2006, 01:07 PM
Chud  is offline
I imagine that would be slightly weird because the 321's are made of mahogany and the 7321s are made of basswood.
I had a random go at making it though (i'm really bored):
This actually seems like a pretty good idea. I'm thinking about selling my RG321MH and my old RG7420... But prehaps i can do this
Old 03-09-2006, 01:32 PM
caprile  is offline
Actually, I believe the standard 321 is made of basswood, so it probably would be a perfect match!!!
My idea is to eventually buy both used, which would be really cheap, and had the body worked out, so both have direct mounted pickups, and the simplest electronics...if the beast works, then you can buy some good gotoh bridges (like the ones on PGM's), good pickups, tuners and there it is!!!
Old 03-09-2006, 01:56 PM
Chud  is offline
Ah there must be a different 321 then because the one i own is made out of mahogany
bridge position, david mccarroll, direct mounted pickups, double neck, floyd rose, mounted pickups, output pickup, squier strat
Guitar Player, Guitar World Back Issues (Satch & Vai) jippy Classified Ads: Guitars and Gear 2 12-24-2005 01:40 AM
American Master project guitar littlegreenman Classified Ads: Guitars and Gear 7 05-22-2005 03:45 PM
How to transport a guitar to Jemfest for flyers. - Safety fi Gabe Nickelson Jemfest Forum 7 05-09-2001 03:37 PM
Project Guitar Ideas - Opinions wanted on project jem7vwh Tech: Setup, Repairs and Mods 11 12-20-2000 12:27 AM
