Advantages of a Neck Thru guitar?
Discussion about any other 6-string guitars not made by Ibanez.
07-10-2008, 12:10 AM
ELicari
Posts: 238 - iTrader: (
What do you think are the advantages if any of a neck thru guitar?
ELicari
Find all posts by ELicari
07-10-2008, 01:38 AM
neotoxin
Posts: 17 - iTrader: (
Re: Advantages of a Neck Thru guitar?
easier access to
upper frets
Sustain?
neotoxin
Find all posts by neotoxin
Sam D.
Posts: 46 - iTrader: (
first off would be the increased sustain, the second would be the smooth neck heel for
fret access
. the bad part would be if you crack your neck, game's over
Sam D.
Visit Sam D.'s homepage!
Find all posts by Sam D.
07-10-2008, 01:48 AM
CityofBlindingLights
Posts: 563 - iTrader: (
Well, you'd get better sustain on a neck through because there's no gap between the neck and body, offering a more direct transfer of tone from the neck.
You'd also have better access to upper frets, as there'd be no need for a heel, offering you unlimited access to all frets.
However, if you have any neck problems, aside from the truss rod and nut adjustments you can't do anything.
EDIT: just noticed, this has been posted by the guy above me
Find all posts by CityofBlindingLights
07-10-2008, 07:38 AM
Dino
Posts: 1,721 - iTrader: (
Actually I was recently told that a bolt on has the best sustain, set neck second place and Neck-thru the least amout of sustain in a scientific experiment.
Same guy told me that a larger/heavier headstock improves sustain.
Dino
Find all posts by Dino
07-10-2008, 08:29 AM
ELicari
Sam D.
first off would be the increased sustain, the second would be the smooth neck heel for fret access. the bad part would be if you crack your neck, game's over
Right! If you break the neck time to get a new guitar,but i`ve had probably over 40 guitars in my time and i never broke a neck!
It`s interesting how some people say the sustain is better on neck thrus and some say it`s not as good!
ELicari
07-10-2008, 08:45 AM
DavyH
Posts: 904 - iTrader: (
Dino
Apparently the plan behind the body-sized headstock on a certain manufacturer's guitars?
No-one else seems to think so though and I doubt neck-throughs got the reputation for endless sustain without cause...
DavyH
Find all posts by DavyH
07-10-2008, 10:55 AM
jim777
Posts: 8,943 - iTrader: (
Things get reputations for all sorts of stupid and valid reasons; it doesn't mean those reputations are valid.
jim777
Find all posts by jim777
07-10-2008, 11:02 AM
ColinMmmmm
Posts: 1,068 - iTrader: (
Maybe the rep for having poor sustain comes from neck-thrus with poor quality/badly set up
floating bridges
? Otherwise it's a no-brainer. Although a bolt-neck can have comparable sustain if the neck joint is snug (in my opinion).
ColinMmmmm
Find all posts by ColinMmmmm
07-10-2008, 11:04 AM
DEADTUNES666
Posts: 2,175 - iTrader: (
Reviews: 12
Well the big advantage is that when the truss goes, or the neck breaks you're screwed and have to shell out more money for a new guitar...But that's only an advantage to the guitar manufacturers.
DEADTUNES666
Visit DEADTUNES666's homepage!
Find all posts by DEADTUNES666
07-10-2008, 11:06 AM
Pickles_the_Drummer
Posts: 70 - iTrader: (
Dino
hmmmm............had he recently experimented with peyote?
Pickles_the_Drummer
Find all posts by Pickles_the_Drummer
07-10-2008, 11:14 AM
Pickles_the_Drummer
ELicari
I've got 5 guitars. A UV777BK (bolt on), a Jackson rr24 (neck thru), Fender Strat (bolt on), Dean ML (neck thru) and a Squier Tele (bolt on).
Of my guitars, the neck thrus have without a doubt the most sustain. They also seem to have a "fuller" tone, like none of the vibration is going to waste. True sustain is a combination neck thru/string thru IMO, but I like floyds, so neck thru will have to do
Pickles_the_Drummer
07-10-2008, 01:00 PM
Triggerman9
Posts: 88 - iTrader: (
In near 20 years of playing neck thru's, the only breakage ,cracks or warp I've seen was from a music store dropping something very heavy on mine. Other than that, how exactly do you go about breaking the neck on any guitar? Yes Vai broke Evo's neck once, but he acts quite a bit more aggressively on stage than I do.
Otherwise, I've played some of the finest bolt neck guitars around and I'll tell you IMHO, none of them sustain as good as a finely crafted neck thru.
Yes there are crappy neck thrus just like there are both excellent and crappy bolt neck guitars.
The
upper fret access
, combined with the brightness (I said bright not brittle) and the sustain of my neck thrus is second to none...
And yes I do own a jem (a 7DBK) and it is a top notch guitar... but I believe my neck thrus play and sound a bit better.
Triggerman9
Find all posts by Triggerman9
07-10-2008, 01:12 PM
kotornut
Posts: 1,847 - iTrader: (
Neck throughs have those obvious advantages people listed in the thread. But I have to be honest after own/playing all the types of guitars I feel that usability of the sustain is the thing people forget. I don't mean that something can sustain for too long I mean that usually bolt-ons that are well made sustainlong enough for almost any playing situation. Before you shell out extra cash just for a neck-through ask yourself "Do I currently on my bolt-on really lack sustain?"
I just don't see why I need to get double the sustain I already have. It'll never be long enough naturally to become like a sustainer pickup's usability and almost every note I let sustain sustains for long enough for anything I can think of. How much does one really need?
On the subject of tone I can't comment because that is too subjective. So if you think the tone is better on a neck-through guitar then go for it.
My point is simply if I had to pay a ton more to get a neck through just for say an extra second or so of sustain that'll probably turn into feedback with distortion then I wouldn't do it. I've never had any lack of sustain on a bolt on.
kotornut
Visit kotornut's homepage!
Find all posts by kotornut
07-10-2008, 05:21 PM
Drew
Posts: 4,538 - iTrader: (
I actually prefer bolt ons, FWIW. It's something about the harmonic content - there's a bit more in the midrange on a neck thru whereas the fundamental and upper harmonics on a bolt on are a little more prominent by comparison, because of what's not there... It translates into a clearer tone with a bit more sparkle and snap to the attack. Likewise, the body wood comes to play more of a part in the sound with a bolt on, whereas the neck through's construction means the neck wood tends to dominate.
I'm a Strat guy from way back, so I just sort of dig the sound of a maple necked bolt on with an ash or alder body. Personal taste, I'll admit, but it's what I like.
Drew
Visit Drew's homepage!
Find all posts by Drew
amp settings
floating bridges
fret access
neck scale
upper fret
upper fret access
upper frets
how do i fix a synsonics guitar?
how to fit led guitar neck
what age guitar
how to swirl a guitar
how do you put the strings closer to the neck on a ZR tremalo
Looking for a guitar neck for....
TheJazzTerminator
02:58 AM
Advantages of 41mm nut width?
Devon8822
12:55 PM
Neck from trem guitar on a hard tail guitar?
Riddles
04:53 PM
Advantages of a 7 string - what are the atvanteges of a 7 st
children of bodom
Other 7-string Guitars
12:48 PM
Pedals vs. Rack system - Advantages & Disadvantages
ANOVA
Gear and Equipment
09:09 PM
05:12 PM
