Old 07-27-2009, 05:21 AM
ThisKar  is offline
Posts: 36  -  iTrader: (0)
Epiphone 58 Korina Explorer Issue
hi, i have a Epiphone 58 Korina Explorer brand new with locking tune o matic bridge and grover tuners.
but my real problem is the balance of the guitar, if i hold it by the guitar strap the neck goes right to the floor, its not so bad when i have it on me but it still it is a problem because i have to kinda hold the neck up.
if i change the position of the strap look (neer the jack) to the top of the horn, you know what i mean:P but would that fix the problem?
any advice would be appreciated^^
Old 07-27-2009, 08:55 AM
humpy  is offline
Posts: 207  -  iTrader: (0)
Re: Epiphone 58 Korina Explorer Issue
I tried that with a non reverse body thunderbird bass and it didn't work. The bass is a 5 string, so I would imagine quite a bit heavier in the headstock than your explorer, and the shape obviously different but doing what you suggest did not work at all.
The only thing I found that helped was not using a nylon webbed (seat belt material) strap. I paid the bucks for a thick leather strap that grips my shoulder well and that helps a lot.
Hope this helps, good luck.
Old 07-27-2009, 09:34 AM
ThisKar  is offline
okay understand
thanks^^
it's just that the body is korina and the neck is mahogany so the body is light compared to the neck. but i hope it will work^^
Old 07-27-2009, 09:41 AM
Homebake  is offline
Posts: 1,041  -  iTrader: (1)
i'm not 100%, but there is a thread floating around here on jemsite somewhere about altering the strap pin position on an ibanez xiphos to stop neck dive i think.
search around for a bit. may help you.
Old 07-27-2009, 10:52 AM
pebber  is offline
Posts: 20  -  iTrader: (0)
it's fairly simple, move the strap button closest to the neck to the area where the neck joins the body on the back, and your guitar will be well strap balanced
Old 07-27-2009, 12:54 PM
Jacob K  is offline
Posts: 183  -  iTrader: (0)
I know someone who thought his 540P-II was out of balance, so he put a big chunk of iron in the control cavity. Worked for him!
Old 07-27-2009, 01:34 PM
marianozz  is offline
Posts: 2,221  -  iTrader: (20)
Had an Epi Explorer once and i had the same problem... Thought i would hate it but i ended up learning to live with it and loving it...
A less slippery strap helps, too... I had a leather one that was rugged on the inside...
Old 07-27-2009, 07:39 PM
ThisKar  is offline
okay okay...
i'll try to move the strap lock to the neck joint to see if that helps
Old 07-27-2009, 07:59 PM
ThisKar  is offline
i moved the strap lock to the neck joint and it workd^^
the only problem now is the where the strap lock used to be, it's a korina body in natural finish so i cant just take a piece of wood and shove it in
Old 07-28-2009, 11:01 AM
pebber  is offline
sure it does
I wouldn't call the rest a problem, just leave the tiny hole unplugged..
Btw, it's not a real Korina body on these.
Old 07-28-2009, 12:03 PM
ThisKar  is offline
really:S that's strange... what is it then? mahogany
Old 07-28-2009, 01:22 PM
pebber  is offline
more then likely three or even four pieces of Alder or Mahogany glued together with some Korina veneer on top.
Epi lists the guitars as being made of Korina, not as Solid Korina which is logical since Korina is too rare/expensive to be sold so cheap.
Old 07-29-2009, 07:37 AM
ThisKar  is offline
understand... because when i look at the top it does look like a veneer top, and on the sides you can se where the edges meet...
alder and mahogany, hehe funny combinations
Old 07-31-2009, 11:35 PM
ThisKar  is offline
the only prblem i have now is that there is something wrong with the way it's been wired.
it wont shut up unless i turn all the knobs down, both volumes and the tone.
and if i use the bridge pickup and have the volume and tone sett to max and then turn the bridge volume down it still isnt off, same with the neck
you have to turn all knobs off for it to shut up.
is there anything i can do about it?
i can solder it again if thats what it takes
Old 08-01-2009, 12:01 AM
callen3615  is offline
Posts: 1,412  -  iTrader: (7)
Get a strap with suede on the back of it. It will keep it from sliding.
epiphone explorer
Fun Mods to Epiphone Explorer quiksilverdew Tech: Setup, Repairs and Mods 11 05-27-2007 12:29 PM
WTT: Flextone II HD Head, Epiphone Custom Reissue Korina Flying V and more... ZOMB13 Classified Ads: Guitars and Gear 0 05-10-2007 10:48 PM
FS: Custom Epiphone Korina '58 Flying V Reissue and misc Guitar parts ZOMB13 Classified Ads: Guitars and Gear 3 05-01-2007 01:16 AM
Epiphone Explorer W/ 2 EMG 85's SpikeSocietySucks Classified Ads: Guitars and Gear 0 11-27-2006 07:31 AM
Epiphone 1958 Korina Flying V savetheplanetx2 Classified Ads: Guitars and Gear 3 01-07-2006 02:48 PM
