Old 08-17-2001, 04:03 PM
gkelm  is offline
Posts: 1,564  -  iTrader: (8)
Fernandes sustainer strat - ...arrived a couple weeks ago
Here's one of my latest experimental toys from ebay...
http://jemsiteforum.com/sharefiles/i...nandes%201.JPG
It's a Fernandes strat copy with sustainer...and it was fairly cheap. *I've wanted a traditional looking strat, but with something more. *Had been toying with the idea of a Warmoth project, but thought this would be worth a whirl. *Thought I'd post a little review as these get inquiries here occasionally.
Impressions...
The body is what first attracted me...it appears to be solid alder (3 pc?) with a 50s style tobacco burst...good looking finish. *It's fairly light, partly due I'm sure to the extra routing for the sustainer electronics.
The neck is fairly traditional strat style, small frets, shallow v--playable but does not have a high quality feel. *Maybe a Warmoth replacement needed?
The hardware is so, so...the trem functions about like any strat trem (ain't no edge).
The pickups are not very good...lowish output and not impressive tone. *I have a set of Fender CS Fat 50s I may pop into the middle and bridge to see how that helps. *I was pleased to find that the neck pup functions as a magnetic pup when the sustainer is off...it sounds kinda thin, but at least is works.
The sustainer works...as far as I know it's the standard Fernandes unit. *It only functions with the bridge pup...a bit limiting IMHO. *It doesn't pump out the sustain as I expected it would...it works best with lots of gain and more volume...a compressor helps too. *I suspect it only works as well as the bridge pup. *Probably needs a higher output pup in the bridge to make it sing--thinking a SD Lil' 59.
For comparison, I just picked up a cheap/mint/used Fender Mexi strat...which generally feels and sounds like a slightly better guitar (this mexi happens to be one of the better ones I've played). *I think with some upgrades (neck &amp; pups) the Fernandes might be a nice piece, and still come in at just a tad over $400 total.
Anybody else have experience with sustainer guitars?
Greg
Old 08-17-2001, 11:02 PM
Vai is God  is offline
Posts: 84  -  iTrader: (0)
I have a Fernandes Monterey with a sustainer system.
It should sing like hell no matter how much output the pick ups have, some suggestions:
  • One of those knobs should control the intensity of the sustainer, turn it all the way up.
  • There should be a push/pull pot that changes it from sustain to feedback.
  • And lastly, and most importantly, check the battery in the back of the guitar. There should be a red light that you can see through the plastic back-peace. If the battery is low, the sustainer won't work nearly as well, and the pick ups will lose output. If the battery runs out completely, the guitar is dead.
I hope this helped, but you probably already knew all that. I don't know if your guitar works the same way as mine, though.
bridge pup, neck pup, strat style, strat trem
