Floyd Rose II - Jemsite
Old 01-23-2004, 06:57 AM
Heka  is offline
Posts: 174  -  iTrader: (0)
Floyd Rose II
Which one is better Original Floyd Rose or Floyd Rose II? What´s the difference between the two??
Old 01-23-2004, 11:19 AM
guitarkatana  is offline
Posts: 635  -  iTrader: (0)
The original. Stay away from the floyd II, it sucketh.
Old 01-23-2004, 11:35 AM
dex  is offline
Posts: 2,074  -  iTrader: (3)
One cosmetic difference - the string lockup screws are different
Soundwise the FRII is more mellow sounding and on an unplugged guitar it sounds more like a Gibson would whereas the FR has that brittle ring that sounds more like a Fender.
Old 01-23-2004, 07:05 PM
pawel  is offline
Posts: 2,674  -  iTrader: (3)
Isn't FRII the licenced version of OFR?
Old 01-23-2004, 08:12 PM
frankfalbo  is offline
Posts: 1,893  -  iTrader: (24)
The FRII is just the Schaller knockoff. Most of the time it was made by Schaller anyway, but some were Korean and they are really bad. So long as it says "made in Germany by Schaller" in the little square under the trem arm it should be a good trem. That goes for other Jackson and Charvel trems too. Some of those are Schallers, and they're fine, but others are asian-made to resemble the Schallers and they were really bad.
Old 01-25-2004, 06:48 PM
nickcoumbe  is offline
Posts: 2,561  -  iTrader: (0)
Reviews: 34
I have recently been converted to Schaller trems. I know the ones that I use (non lo-pro) are the fr2 design.
I have to say that if you get a Schaller you wont regret it, they are so ergonomic, and much less bulky than the Edge for instance. Definately the best floyd of all.
Old 02-08-2004, 05:57 PM
BCShredder  is offline
Posts: 135  -  iTrader: (0)
blah
Orig Floyd or no floyd @ all.... I'd still take a kahler Pro over a Floyd anyday though.
Old 02-18-2004, 06:04 PM
Octavio  is offline
Posts: 88  -  iTrader: (0)
The original Floyd Rose, not the licenced.
Is much strong, well built and high detailed than the Floyd II, which is different completely. As upper said "Stay away from the Floyd II"
Old 02-18-2004, 09:05 PM
If the Floyd II says "Made in Germany by Schaller" next to the trem arm it is a fine tremolo. If not, then it is asian made and it is not good.
Old 03-02-2004, 02:36 PM
phlame  is offline
Suspension: Multiple Users
Posts: 916  -  iTrader: (2)
original fr all the way
Old 03-02-2004, 07:25 PM
JESTER700  is offline
Posts: 2,234  -  iTrader: (0)
Actually, I thought the Kahler Steeler was the best Floyd of all. But the OFR, Schaller, and Edge all take a pretty close second.
Old 03-02-2004, 08:31 PM
dex  is offline
I've got Schaller made FRII on 2 guitars (Jackson SL3 and ESP MII Deluxe) and I'd say it's a very good, solid tremolo.
As I said above the only noticeable difference between OFR and FRII is cosmetic - the string lockup screws are different but also the base on the FRII is cast with knife inserts and it sounds melower than OFR or an EDGE.
Bottom line, if you set it up well it will perform as well as any OFR you care to throw at it.
The only difference is in feel.
Old 03-09-2004, 07:26 PM
metalguy  is offline
Posts: 427  -  iTrader: (5)
I got a Kramer for Christmas back in 88 and it had a Floyd II. The thing that sucked was that the strings went through the trem almost like a stopbar and then went over a sharp "hump". The strings constantly broke.
I recently stole pieces from another trem and made it locking style(cut off the ball end and pinch it in the little block).Much better.
Old 03-09-2004, 07:47 PM
That's not the same Floyd II everyone's talking about. Yes, those sucked, and they were Korean.
Old 03-09-2004, 08:02 PM
metalguy  is offline
Well, it was cool when I was a Van Halen fanatic at age 14 haha. Whammy dives out the ass.
esp mii , floyd rose , schaller trem , string lock , trem arm , van halen
WTB: Black Gotoh Floyd Rose or Black Original Floyd Rose supergirl20_06 Classified Ads: Guitars and Gear 1 06-11-2011 08:14 AM
WTB Original Floyd Rose or GOTOH floyd rose callen3615 Classified Ads: Guitars and Gear 3 01-22-2011 03:12 PM
Lic Floyd Rose vs Orig Floyd Rose aradine Tech: Setup, Repairs and Mods 1 12-30-2008 07:38 PM
FS: Original Floyd Rose & Floyd Rose 2 -zct- Classified Ads: Guitars and Gear 6 09-02-2005 04:07 PM
Floyd Rose Cavity: Lo Pro Edge same as Original Floyd rose - Captain Ron Tech: Setup, Repairs and Mods 2 09-06-2001 01:06 AM
Powered by
