Help me ID This Strat Model
Discussion about any other 6-string guitars not made by Ibanez.
Page 1 of 3
01-23-2008, 09:34 PM
CosmicDebris
Posts: 3,216 - iTrader: (
I found this one through local channels and have not been to check it out yet but the dude is asking $975 and hopefully will take less
. Looks like something I might be interested in but would like more info. I have not had a chance to get more info from the dude yet but most likely will get more info.
What can you dudes tell me about it by these pics?
CosmicDebris
Find all posts by CosmicDebris
01-23-2008, 09:37 PM
elcid
Posts: 8,718 - iTrader: (
Re: Help me ID This Strat Model
I have one and it's awesome. I keep forgetting to upload pics, mine is a blueburst. Fender Deluxe Ultra Strat or something along those lines.
Gold Lace Sensors
locking tuners
, awesome neck, tremsetter. TBX control. $975 isnt a bad price at all.
elcid
Find all posts by elcid
01-23-2008, 09:46 PM
CosmicDebris
elcid
Fender Deluxe
Gold
Lace Sensors
, locking tuners, awesome neck, tremsetter. TBX control. $975 isnt a bad price at all.
Is the Tremsetter factory installed or is it something you had done or did? What is TBX control? I have never owned a strat but would not mind giving one a shot for when I want something different than my RGT220A.
CosmicDebris
01-23-2008, 09:56 PM
elcid
Its factory installed. The spec sheet says it has one, but I havent had a chance to look yet and make sure. The TBX control is what the Clapton Strat has, it's some kind of active tone control. I think the other tone control is something special too, but I really dont remember right now.
I wishI could help but it;s been crunch time at work and I've been working 76 hour weeks so Im kind of fried right now. I will look into it more and get back to you. Ibanez 249 had one exactly like mine for sale here awhile ago. In fact he found the one I got for me on the bay.
elcid
01-23-2008, 09:57 PM
CosmicDebris
Cool, I will have to meet up with the dude this weekend and check it out and lowball him
CosmicDebris
01-23-2008, 10:15 PM
elcid
It might be a Deluxe Ultra Plus, you know how Fender is.
Good luck man, I dont think you'll be disappointed.
elcid
01-23-2008, 10:19 PM
elcid
This is a pickup assembly off a
Strat Plus Deluxe
, but other than the color of the pickups, they are wired exactly the same. Inside you will find the Plus has a Fender TBX tone control on the lower tone knob. This is not an active system, as some believe, (using a battery as found on the 20db boosters on the Clapton Strats), but it is simply a stacked set of potentiometer that cuts either treble or bass, where as the standard tone control only cuts the treble. So we have: T (treble) B (bass) X (Cut) thus TBX. When you turn this knob, you can feel a halfway point—this is tone neutral (#5 on the knob!). This TBX control gives the bridge and middle pickup a unique variety of sounds! When the 5-way switch is in the 4th position, by turning the tone control you can get a bell like sound to a honking out-of-phase mid-range sound. Put the switch in position #2 and, you get a quack, or a hollow twang! The 1st tone control is a standard Fender 250 k potentiometer as is the volume control.
Here is some (maybe!) useful information. The Lace Sensors had only white and orange wires up till around 1989-1990, then the Lace Music Company added the extra green ground wire. Also the Strat Plus used a different wiring schematics than the older Strats—the TBX tone control was connected to both the middle and bridge pickups. Older Strats had the lower tone control connected to the middle pickup and the bridge pickup was bypassed all together. This newer design gives a person a lot more tone capabilities.On position #4 you can use both tone controls, one on the neck pickup and the TBX on the middle pickup while having both pickups on.
Many of the Plus Series, but not all, came with a Hipshot Trimsetter, which compensated for
string tension
. Once set up correctly, and after getting the guitar in tune, they stay in tune. If a string breaks while playing, the Tremsetter will compensate and the guitar will stay in tune. (How to set one of these up will show on the "tips" page
elcid
01-23-2008, 10:20 PM
elcid
The Strat Plus Series was introduced by Fender in 1987 and was the highest end
production model
next to Fender's
Custom Shop
guitars. (Production stopped in late 1998 or early 1999.) The Plus Series consisted of The Plus, The Plus Deluxe, and then later, in 1990, The Ultra.
elcid
01-23-2008, 10:22 PM
elcid
The standard Plus usually came with 3 Gold
Lace Sensor
pickups. These pickups were designed to give a 50's single coil sound, with a lot of chime and even bell like tones. Crisp, and quiet, they really do perform like a 1950's pickup, but with no hum! The Lace Sensors were a whole new design of pickups—having a unique radiant field barrier system that surrounds both the coil and magnets, eliminating annoying 60-cycle hum. The patented Lace Micro Matrix Combs replace traditional bobbins, yielding a wider tonal range and better string balance than traditional pickups. The Gold Lace were the pickups of choice for years by Jeff Beck,
Eric Clapton
, and Buddy Guy on their Signature Series.
elcid
01-23-2008, 10:28 PM
CosmicDebris
Very very helpful. Thanks dude. I called the dude and set up a time for Sat morn.
CosmicDebris
01-24-2008, 02:59 PM
John C
Posts: 50 - iTrader: (
I can add some more timeline detail and my $0.02 is I'm 95% sure the guitar in question is a Strat Plus - easily confirmed if the Lace Sensors have the gold lettering. A Plus would also have a screw-in trem arm. Based on the roller nut shown it has to fall in the 1987 to late 1993 range; Fender switched from that Wilkinson roller nut to the narrow LSR roller nut sometime in late 1993.
The Plus Deluxe would have Lace Sensors with other color lettering - the very early ones would have blue/silver/blue lettering; by sometime in 1989 they switched to blue/silver/red (red in the bridge). Plus Deluxes usually had "custom" colors - the earliest ones were offered in "Stratoburst" colors (outside edge silver, inside "burst" a dark color like blue or black). By circa 1989/90 they settled in on just bursted colors as they were using ash veneers on the front/back of the body - the blue and red bursts used lake placid blue and
candy apple red
for the opaque edges. A Plus Deluxe should also have a snap-in trem arm.
When the Ultras came out in 1990 they had figured maple veneers front/back. They had blue/gold or silver/dual red lettered Lace Sensors. The "Dual" Lace was two single-coil size Lace Sensors in a humbucker housing, and had an extra mini-toggle to control which coil was active (front/both/rear). The early Ultras also had
chrome hardware
instead of satin and an ebony board. This definitely isn't an Ultra.
All three had the Hipshot Trem-Setter until late 1993; when Fender switched to the LSR nut, they also switched the Plus Deluxe and Ultra to the "Fender/Floyd Rose" single-locking bridge. They did continue to put the Trem-Setter on the Strat Plus.
One last "oddity" from the early FMIC era - when FMIC bought Fender from CBS, they only got the "intellectual property", i.e. names, designs, patents, paperwork, etc. CBS sold the factory and machinery separately. Part of that "paperwork" was a bunch of ready-to-use headstock decals for Strats and Teles that had "E4XXXXX" serial numbers. Normally, "E4XXXXX" would indicate it was a 1984 guitar - "E" for "Eighties" and "4" for the year. These were used on 1987 American Standard Strat, Strat Plus, and Strat Plus Deluxe models. They are not 1984 guitars; the 1984 Strat was a completely different design. I can't accurately blow up the headstock photo, but this one might have an "E4XXXXX" number, making it a 1987 guitar.
Edited to add:
Also, as an FYI the Plus/Plus Deluxe/Ultra series were dropped at the end of 1997; the American Deluxe series was introduced as the replacement at the 1998 Winter NAMM, although some final units probably trickled out during early 1998 as Fender always uses up their parts on hand. Regardless, based on the headstock decal design and Wilkinson roller nut this guitar could be no later than a 1993 model
03:04 PM
John C
Find all posts by John C
01-24-2008, 03:26 PM
trynyty
Posts: 60 - iTrader: (
This link may help you out:
http://www.xhefriguitars.com/page3.html
trynyty
Find all posts by trynyty
01-24-2008, 04:41 PM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
It's a
Strat Plus
Deluxe I believe with gold lace sensors. Mine's the same blueburst Cid's talking about. I think $975 is a bit high for the guitar but, I can definitely attest to the fact that it plays superb and you can get a lot of sounds out of it.
Here are some pics of mine:
Jimmy
jb4674
Find all posts by jb4674
01-24-2008, 04:49 PM
John C
trynyty
That's a good site but it does have some inaccuracies - primarily the part about the Strat Plus continuing through 1998 to 1999. I know they were dropped and replaced by the American Deluxe series as of 1998 - I had a 1998 Am Dlx that I got in May, and it was the first one to hit the stores here after they were announced at the NAMM show.
The rest of it is really good; particularly the sections on the various roller nuts and bridges used.
It's also apparent that most dealers where I was living during the Strat Plus era just preferred to order the "fancy" colors for the Plus Deluxe; I swear I never saw a Plus Deluxe in anything other than a burst or the natural ash (the natural finish meant that the guitars got a solid ash body, and those suckers were always heavy) in either Central Kentucky or Northeast Ohio!
John C
01-24-2008, 04:50 PM
jb4674
Reviews: 6
elcid
Cid, I'll be your best friend forever if you post a how-to guide along with pictures and idiot-proof directions. The Hipshot directions are simply awful and not very helpful.
Jimmy
jb4674
Page 1 of 3
abalone dots
beautiful guitar
bridge pickup
bridge pickups
candy apple red
chrome hardware
custom shop
custom shop guitar
ebony board
ebony fingerboard
ebony neck
eric clapton
fender deluxe
floyd rose
gold lace sensors
guitar shop
humbucker guitar
jeff beck
lace sensor
lace sensors
locking bridge
locking tuners
neck pickup
production model
rosewood board
schaller locking
schaller locking tuners
strat plus
strat plus deluxe
string tension
trem arm
white pickguard
how to take off a bolt on neck on strat
what is the best strat copy
WHAT HUMBUCKER BEST FOR STRAT BRIDGE
how can i tell my guitar model
how to measure scale length on a strat
FT USA Malmsteen strat for JS1000BTB
Dazza1004
09:31 AM
Fender Strat - USA vs Japan?
cowcowcow
07:21 PM
(Warning: Fender Strat Talk!) Strat Dream... - This only too
goldboy
Gear and Equipment
07:24 PM
Fernandes sustainer strat - ...arrived a couple weeks ago
gkelm
11:02 PM
Bridge Humbucker for Strat - Help me choose one
Karmann
Tech: Setup, Repairs and Mods
08:33 PM
11:33 PM
