Old 07-09-2002, 11:58 PM
Merlin88  is offline
Posts: 14  -  iTrader: (0)
I'm gonna make a Double Neck!
Hey, I have decided to make a double neck guitar out of two of the ones i already have. A Jackson and a kramer. Will this be hard? If its to hard i'd like ot know of a double neck i can get for around 200. im scared!!!
Old 07-10-2002, 11:27 AM
butch  is online
Posts: 224  -  iTrader: (4)
Prepare for ALOT of work. Measure three times to cut once. Patience is everything. Even with the best tools and facilities, it will take days to finish the body.
You will need plenty of material to fill in the bottom of the body. Since both of the guitars are "Strat" shaped, the bottom contours (where the strap buttons are) won't line up flush. It will look like a rounded "W". You will need to fill this in with poly (or something similar), to make it flush. You will have to do ALOT of sanding to get everything smooth and even.
Not to mention, the wiring may be difficult, depending what you want.
I'd say look for a used Epiphone, Carlo Robelli, Rogue, Cort, Galveston, or something like that. It will satisfy your double neck craving and not kill your wallet (not to mention frazzle your nerves).
Cheers,
Butch
Old 07-10-2002, 11:32 PM
Merlin88  is offline
alright, im scared.. Would it be any eayser with two vee shaped bodys?
Old 07-11-2002, 01:42 AM
littlegreenman  is offline
Posts: 2,626  -  iTrader: (4)
I would suggest measure up from the 2 bodies you have, and build yourself a new body rather than mess with existing ones, that is very doable, and you don't risk wrecking 2 guitars, you mess up your new body, you can still put together your 2 guitars again, you mess up your existing bodie's you're out 2 guitars.
Old 07-13-2002, 09:44 PM
Pablo  is offline
Posts: 633  -  iTrader: (1)
Warmoth sell doubleneck bodies
Strat and tele types is I'm not mistaken
Old 07-14-2002, 01:06 PM
gkelm  is offline
Posts: 1,564  -  iTrader: (8)
Even thought the Jackmer (or Kramson) concept sounds intriguing, I vote with the others here for the construction or purchase of a doubleneck body/guitar.
Greg
double neck, strap button, strap buttons
