Neck Lip overhang removal?
Discussion about any other 6-string guitars not made by Ibanez.
12-19-2008, 12:23 PM
AustinPlaysGuitar
Posts: 99 - iTrader: (
Hey! on my project guitar. the neck I have is amazing but at the bottom. the fret board over hangs about 1/3 of an inch past the heel of the neck and I need need it removed because It overhangs in the humbucker cavity and I cant get my pups in w/o taking the neck off. I installed the first set of pups with the neck of but now that I'm replacing them, I need to get them out and get the new ones in and I really dont want to remove the neck again.
Anyway. suggestions on removing the lip? should I file it off? some how cut it off? all help is appreciated!
AustinPlaysGuitar
Find all posts by AustinPlaysGuitar
12-19-2008, 12:53 PM
Algiman
Posts: 2,553 - iTrader: (
Re: Neck Lip overhang removal?
Assuming that the dimensions of that guitar are accurate to Ibanez, it looks like you've set the neck into the body slightly too far. Hard to be sure from the angle that this pic was taken mind you.
Algiman
Find all posts by Algiman
12-19-2008, 12:57 PM
AustinPlaysGuitar
Algiman
the dimensions are Ibanez but the neck is set correctly its just then length of the fret board. I believe early 90's Ibanez bodies had the fretborad flesh with the heel or I was something like that and I didnt know that until after getting it :\ and sorry about the picture. its then only one I have that shoes the fretboard up close
AustinPlaysGuitar
12-19-2008, 01:25 PM
nuno
Posts: 4,725 - iTrader: (
dislexic today?
anyway, i think the only thing you can do is sewing it out. if you don't have a sewing machine at home, take it to a luthier, he wouldn't charge you more than a coffee.
and... it's me, or the last 3 frets are all the same distance?
nuno
Visit nuno's homepage!
Find all posts by nuno
12-19-2008, 01:27 PM
AustinPlaysGuitar
nuno
dislexic today?
sew it? what do you mean? and in the pic the distance looks really close but thay are bigger lol
AustinPlaysGuitar
12-19-2008, 01:40 PM
jim777
Posts: 8,943 - iTrader: (
You should be able to dremel it off, but be careful or it will come out looking terrible. A file would take longer but would give you a straighter line. Maybe a bit of both
Don't take it off all the way to the fret though, just take off what you need to and no more.
jim777
Find all posts by jim777
12-19-2008, 01:41 PM
AustinPlaysGuitar
jim777
thats what I figure. thanks! I'm still in the dark about sewing it?
AustinPlaysGuitar
12-19-2008, 01:44 PM
Viper-sfm
Posts: 439 - iTrader: (
I think he means sawing
In any event, the neck seems to be a little skewd in relation to the body cavities...make sure the frets are a perfect 90 degrees to the pickups. Also, measure from the nut to point where the strings touch on the bridge. It should be very close to 25.5" or 648mm.
I think the best would to bring it to a Luthier so he can check those things for you.
Viper-sfm
Visit Viper-sfm's homepage!
Find all posts by Viper-sfm
12-19-2008, 01:48 PM
AustinPlaysGuitar
Viper-sfm
yeah its a little off because its not screwed in yet, its just resting on the body in that pic so it leaned a bit :]
AustinPlaysGuitar
12-19-2008, 01:56 PM
Viper-sfm
Ah, ok. In that case, put it in the right spot and measure the thing I said before. If it checks out, then you are set....if not, then it'll need readjustments.
Viper-sfm
12-19-2008, 11:44 PM
indeedido
Posts: 215 - iTrader: (
Hey look, he has the new '09 Jem prototype, hard tail. LOL
indeedido
Find all posts by indeedido
12-20-2008, 11:55 AM
AustinPlaysGuitar
indeedido
AustinPlaysGuitar
parker are they neck thru
how can i tell thin or standard neck prs
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
Old style RG neck with overhang question.
john1880
Tech: Setup, Repairs and Mods
01:14 AM
Inlay removal - 7621 neck
Bluestreak
09:58 PM
USRG30 neck removal
gkelm
10:29 PM
Pot wax removal
Zeek
Pickups & wiring
10:23 AM
inlay removal for neck blackout
shawn
02:13 AM
03:27 PM
