Old 11-04-2009, 02:27 PM
Magical Muffin  is offline
Posts: 536  -  iTrader: (0)
Need help identifying my Jackson
Hopefully there's at least a few big Jackson nuts here, as I don't feel like making an account at the Jackson forum.
The thing I'm wondering about is the Pro series they had going in the 90's, and whether or not my guitar is one of those 'really good' ones, mainly out of curiosity.
A bit ago I bought a Jackson for a 80-90$ from a friend of a friend who didn't want it. It needs a good cleaning, setup, etc, but that's not the important part. On the headstock it has the 'professional' thing next to the logo. I decided to try to do some research, and apparently Japan made some USA quality guitars in the 90's, but I couldn't find that much information. All the MIJ Pro guitars I see are all fancy with inlays, body work, etc, but mines pretty plain, or 'not expensive looking'. Not cheap, but you hopefully get the picture.
The specs on my guitar:
22 frets, normal dot inlays, rosewood fretboard
Jackson tuners
Liscensed FR
Sort of a 'shiny' black, superstrat shape
HSH, 5 way switch and 1 volume control
That's about all I can think of. Can't get pictures, too much work.
(Edit: It also has jumbo frets and a thin neck, as well as a blank truss rod cover)
The bottom of the volume control (on the underside of the guitar) it says 'made in Japan' but I couldn't find any other indication anywhere else on the guitar.
And the serial number 924811 if that helps at all.
So does anyone know more about this than me? Is it one of these fabled ultra high quality guitars? Is it a steal at 90$ (Most guitars are, I guess)?
Thanks.
Old 11-05-2009, 03:43 AM
Mickolai666  is offline
Posts: 20  -  iTrader: (0)
Re: Need help identifying my Jackson
http://jacksonguitarpalace.com/forum...05eb39a3e917c0
Jackson import serial numbers are kinda dodge-y.... Try hopping on the forum above, they're gonna ask for pictures. Same with JCF. You can generally get a pretty good idea by the trem cavity and electronics route. also most Japanese had offset dot inlays. if they're centered it could be an indication that it's probably Korean... The Japanese ones are pretty rad, I have japanese ps-4 that rocks my socks. It also could be a fusion, or a mutt with a pro neck. It's hard to say without pictures.
Old 11-11-2009, 04:51 PM
jim777  is offline
Sounds like a '92 Standard Pro something, likely a Dinky if its 25 1/2 scale or a Fusion if its 24 2/4 scale. The Soloists were all 24 fret neck-throughs, so I'm guessing not a Soloist. I'm guessing its a bolt on because its 22 frets also. Standards had the rosewood/dots.
A 92 should be a really nice guitar, yeah The top shelf 90-91's are the best of that lot, but they stayed really nice through 94 from what I've heard. The 90's Soloist Pros I've had I really, REALLY regret parting with.
Old 11-14-2009, 12:40 PM
Yeah, it's most likely the standard pro. It is a bolt on and 25 1/2 scale.
But I'd find it pretty wierd if it was made in Korea, because the electronics said 'made in Japan' on them. I dunno : \
jackson, mij
help identifying my RG.. spkenn5 Other 7-string Guitars 3 05-05-2007 04:43 PM
WTB: Jackson Kelly or Jackson King V (USA, white) etuor Classified Ads: Guitars and Gear 1 04-07-2007 04:41 AM
Help Identifying an RG t1r12003 Other Ibanez Guitars (including Premiums) 9 03-14-2006 03:27 PM
FS: Jackson Rhodes, Jackson Neck beast Jem7RB MK Classified Ads: Guitars and Gear 4 06-01-2005 04:21 PM
Identifying an old RG - Identifying an old RG Weissach Other 6-string Guitars (non-Ibanez brand) 2 12-04-2001 12:08 PM
