Old 06-28-2005, 11:09 AM
sugizo_esp  is offline
Posts: 446  -  iTrader: (0)
Pickguard holes in wrong place
hi
i hv just try to install a new pickguard on my squier strat
its both a 8hole pickguard
but after i got everythign from one pickguard to another....i found that the holes are not in the exact place....and i only manage to screw back 4 of the 8 screws...
any suggestions of waht i shud do??.....re drill the hole or just leave it as it is??
also...just a side question...i found the 12th fret at high E start to buzz on bends...after installin the pickguard...will a normal setup at a guitar tech will fix it?
thx
Old 06-28-2005, 11:36 AM
Ibateur  is online
Posts: 2,948  -  iTrader: (3)
Re: Pickguard holes in wrong place
Re the "holes left empty" what I would do is cut a couple of screws and glue them in place to preserve the visibility.
Re the buzz, yes a setup will normally fix it, though the setup could require fretwork.
Old 06-28-2005, 12:08 PM
elcid  is offline
Posts: 8,719  -  iTrader: (12)
Get a drill and screw the other ones in
Old 06-28-2005, 12:46 PM
thats a gd idea..but doesnt the pickguard come lose or anything?
i dun think the buzz happen before i replace the pickguard....do u think theres anythign to do with the unbalance tension on the neck?..caz i just losen all the strings
Old 06-28-2005, 12:47 PM
about few holes overlap on the other pre-drilled holes..
i dont think the screws will stay in place caz that expands the current hole
Old 06-28-2005, 12:54 PM
jim777  is offline
Leave it as is. Aftermarket strat pickguards are always screwy. If you can turn the guitar upside down without the guard falling off you'll be fine
Old 06-28-2005, 01:39 PM
Flobanez  is offline
Posts: 5,513  -  iTrader: (1)
Agreed. I wouldn't re-drill holes, I'd leave it...
Old 06-28-2005, 04:03 PM
Ibateur  is online
OR ... look for those non-pre-drilled pickguards and match them up then transfer all the electronics from one guard to the new one. Maybe you can trade in the other "new" one at the store.
I recently bought a mighty-mite pre-wired pickguard, thinking that "all strat dimensions are the same". Boy was I wrong. Since the body was a ply-wood poS, I drilled new holes. It sure didn't look pretty.
If the holes are mis-aligned but will reach the original holes, I would NOT even try. You'd end up with ovalled holes.
You could also try the link up there (pickguard paradise) and find out what your options are (for a price)...
Good luck!
Old 06-28-2005, 05:11 PM
Knightmeir  is offline
Posts: 1,074  -  iTrader: (1)
Same thing happened with my strat... so I brought my original pickguard with me the second time to buy one that fit.
Also happened on my VWH... the mirrored guard doesn't line up all the holes perfectly... so I just left them out. It stays in place just fine... no one ever notices.
Old 06-28-2005, 07:25 PM
shredfreak  is offline
Posts: 809  -  iTrader: (0)
I screwed only about 5 screws. Same thing usually on those replacement pickguards but even with only 5 screws the pickguard doesn't fall off.
Old 06-28-2005, 09:25 PM
Good luck!
i got myself a Anodized gold pickguard ...damn it didnt fit..i guess i can now go around and match a pcikguard up now with the one taken off...an actual fender anodized gold cost a fortune and they look the same
Old 06-28-2005, 09:28 PM
what i m worry is that theres only 1 screw on the top side of the pickguard
(in playin position..) while the 2 screws in the middle bottom side fits....and one screw on the bottom side towards the switch
i m just worry the pickguard doenst get a balance support and rips the wood out whn i strat playin heavily n swinging the guitar and moving around
Old 06-29-2005, 12:02 AM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
Bingo. Get a few in and leave it alone... glen
Old 06-29-2005, 05:29 AM
i guess i'll leave it alone with 4 screws and try it out in the coming gig...since i will be using that guitar as main..
i still haven't shield the pickguard yet...pretty noisy...
Old 07-04-2005, 10:21 AM
Maniaaaak!!  is offline
Posts: 49  -  iTrader: (0)
it's quite simple really:
some stratpickguards have 7 or 8 holes and some have 11 or 12. If you change one pickguard for the other only 4 or 5holes will line up and one hole (neard the tone knobs) will not fit.
There's only one solution basically; drill holes or the guard won't be in place properly. You'll risk messing up your wires and/or pickups whilst moving about...
good luck!
guitar tech, pickguard paradise, squier strat
Wrong place I know...but Dimebag Darrell was murdered today RythmicIllusion JEM and Universe Guitars 2 12-09-2004 09:07 AM
What is the best way to drill neck holes in new body..... SilverSurfer2 Tech: Setup, Repairs and Mods 10 04-14-2003 06:41 PM
