Old 05-31-2004, 01:41 PM
jemke  is offline
Posts: 318  -  iTrader: (0)
PRS intonation question
How can you change the intonation on a hardtail PRS?? They are not adjustable in my opinion...
Old 05-31-2004, 03:28 PM
sniperfrommars1  is offline
Posts: 3,309  -  iTrader: (0)
Re: PRS intonation question
By shaving the tail peice. Basically you can only adjust for one string type and gauge setup style and after that your basically lost. I would suggest anyone with this tailpeice design should change it.
Old 05-31-2004, 08:33 PM
Kontalonis  is offline
Posts: 1,006  -  iTrader: (3)
http://www.tonepros.com/Products.htm
Look at the AVT2 Wraparound. Great alternative. Even available with locking studs. Can't be beat!
Old 06-01-2004, 09:25 AM
germX  is offline
Posts: 709  -  iTrader: (0)
the PRS hardtail doesn't have intonation issues if you have .009/ .010 in there. PRS does offer the adjustable version of this hardtail, ask your dealer about it
Old 06-04-2004, 04:17 AM
jemke  is offline
I assume that the bridge is designed for 09 or 010 but I just can't imagine the intonation does not need to be adjusted over the years...
Old 06-04-2004, 05:23 AM
do to inconsistencyes in nut cuts, bridge length swelling and shrinking of wood, thats physically impossibly thats why we use intonation adjustabel tailpeices in the first place. One of my friends has a yamaha acoustic with an adjustable bridge and it has possibly the best overall intonation on a guitar ive ever seen
Old 06-04-2004, 10:52 AM
frankfalbo  is offline
Posts: 1,888  -  iTrader: (23)
Doesn't it have two "master" allen wrench adjusters in the back behind the bolts? I think the intonation is adjustable, just not from string to string. The string to string variance is a little more pre-set. It's only way off if you use a wound G or 11-48's or something like that.
Old 06-04-2004, 10:00 PM
germX  is offline
Sniper: maybe the climate plays a part. i'm putting up in an equatorial climate so i guess there's less prolonged temperature extreme. my McCarty had been in tune since day 1...
as mentioned previously, PRS offers adjustable bridges, in fact, they are default on some hollowbody PRS.
Old 06-25-2004, 10:08 AM
data187  is offline
Posts: 128  -  iTrader: (3)
you can get a tonepros bridge which is adjustable.
check either thegearpage.net or birdsandmoons.com for more prs info.
allen wrench, locking stud, locking studs
