Go Back   Jemsite > Guitars and Gear > Other 6-string Guitars (non-Ibanez brand)
Old 12-26-2005, 02:14 AM
waylay00 waylay00 is offline
Posts: 3,510  -  iTrader: (9)
Retrofitting Edge-Pro or Lo Pro to a guitar with an OFR?
Would I be able to retrofit an Edge Pro or a Lo Pro tremolo into a guitar with an Original Floyd Rose?
What would I need to change, if anything?
Thanks
Old 12-26-2005, 02:28 AM
User01 User01 is offline
Posts: 50  -  iTrader: (0)
Re: Retrofitting Edge-Pro or Lo Pro to a guitar with an OFR?
why dude, edge pro kicks the crap outta the ofr
Old 12-26-2005, 02:35 AM
Yes, I'm completely aware of that, but that wasn't my question.
Old 12-26-2005, 08:17 AM
horstausmforst horstausmforst is offline
Posts: 673  -  iTrader: (1)
The procedure is very similar to a trs-edge conversion;
You'd have to replace the anchors and enlarge the cavity around the trem.
So, if your good with a router and woodworking tools, check the following tutorial:
http://www.projectguitar.com/tut/trs2lopro.htm
PS.
actually the edge (pro) does not "kick the crap outta the ofr". So if your ofr is worn or broken, you should just get a new one.
Old 12-26-2005, 01:51 PM
not my ofr is not broken or worn, it depends on what your looking for in a bridge, and we have different opinions, so i guess we'll have to agree to disagree.
Old 01-05-2006, 10:58 AM
nickcoumbe nickcoumbe is offline
Posts: 1,136  -  iTrader: (0)
I think that the trem posts are drilled in different positions so you may have to fill the originals and re-drill as well as the other routing. The trs is in the same place as the ofr, but the edges are different. I think that they may be further back, and you would have to watch the post getting too close to the cavity.
Old 01-05-2006, 07:24 PM
adamcbest adamcbest is offline
Posts: 825  -  iTrader: (0)
personally i think the OFR is just as good as the edges. i mean.. the other day i played a usa jackson with an OFR and was doing dive bombs and extreme pull ups and it was keeping perfect tune.
Old 01-06-2006, 09:41 AM
+1
I use the schaller floyds and they are every bit as good. I have a custom strat with sperzels and it stays in tune as well as any edge equipped guitar I have. I am sure that setup is really what makes most of the difference between double locking trems.
Saying that, the edge derivatives do feel a bit easier to move initially. Maybe this is because of their size.
Bookmarks
equipped guitar, floyd rose, locking trems, pro tremolo
