Old 08-08-2009, 10:17 PM
callen3615  is offline
Posts: 1,412  -  iTrader: (7)
Routing strat for a humbucker?
So I want a humbucker in the bridge of my strat, maybe a super distortion or a paf. Its got 3 texas specials in it. Can I route out the bridge slot for a humbucker? Heres a pic.
Old 08-08-2009, 10:53 PM
humpy  is offline
Posts: 207  -  iTrader: (0)
Re: Routing strat for a humbucker?
EVH did it, can't see why you can't :-)
My last 3 strats (MIM) have all been routed for a humbucker but have singlecoils in them, If you haven't checked it might be worth a look. Or you can always get the single coil sized humbuckers.
Old 08-08-2009, 10:57 PM
Homebake  is offline
Posts: 1,041  -  iTrader: (1)
the bridge is most likely routed for a humbucker. my squier strat is.
Old 08-08-2009, 11:36 PM
I looked and it is routed hsh. But I would still have to cut out the pickguard right?
Old 08-08-2009, 11:40 PM
CosmicDebris  is offline
Posts: 3,216  -  iTrader: (4)
You could just get a single coil sized hb.
Old 08-09-2009, 12:08 AM
I was thinking of a hot rail.
Old 08-09-2009, 12:23 AM
Never played one but I hear they are pretty cool.
Old 08-09-2009, 02:15 AM
Ayrton  is offline
Why bother when you can order a new one any way you want it for under $30?
Save the original if you can.
Old 08-09-2009, 09:27 AM
I might just do a stacked single coil. Maybe a hot rail. Any other good stacked single coils?
Old 08-09-2009, 03:17 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
You can order new pickguards from fender directly in HSH, SSH, SSS, etc.
Jimmy
Old 08-09-2009, 03:33 PM
toneboy  is offline
Posts: 1,665  -  iTrader: (2)
A stacked single coil won't sound like a "real" humbucker because it still has vertical/pole piece magnets like a single coil. You can can get a higher output pickup but it will still have single coil characteristics.
A side-by-side/rail single coil will sound much, closer to a "real" humbucker because it has a bar magnet. It won't sound exactly the same as an equivalent because the coils are narrower. It doesn't have the same "magnetic window" that a humbucker does.
If you want a humbucker in the bridge, get a real humbucker in the bridge. By that I mean at least get a rail single coil but I would still advise getting a regular humbucker because you will have many more to choose from.
Old 08-09-2009, 07:19 PM
Thanks for the help guys.
Old 08-09-2009, 08:30 PM
EvoGiant  is offline
Posts: 355  -  iTrader: (2)
i've been using Seymour Duncan Hot Rails for years. I dont think a person could hear the difference side by side with a full size humbucker. ymmv
Old 08-09-2009, 08:49 PM
toneboy  is offline
Question - Which full size humbucker is its equivalent?
Answer - There isn't one.
Hence that's not a good example to go by. If one were to use a JB Jr. or Tone Zone S one might here the difference. I know I have. It's subtle but it's there.
Old 08-09-2009, 10:45 PM
Well I just got a used hot rails off the bay.
stratocaster
Possible to put a humbucker in bridge of a S-S-S strat? kyates.yates Pickups & wiring 16 02-09-2010 04:04 PM
Strat humbucker suggestions lttoler Pickups & wiring 5 08-24-2008 12:27 AM
Best Full Humbucker For Fat Strat? Thrash Pickups & wiring 4 07-27-2008 01:35 AM
Best bridge humbucker for a strat?! Smitty Gear and Equipment 16 07-25-2007 03:05 PM
