Old 08-16-2006, 01:51 PM
pera_a777  is offline
Posts: 406  -  iTrader: (0)
Scale lenghts..differences..?
I have been playing 25,5 scal guitars for about 7 years..i am going to buy maybe a 7 string with 27 scale..
What are the differencies..in sound, playability and stuff..?
Thanx very much..
Old 08-20-2006, 07:41 AM
Re: Scale lenghts..differences..?
Anyone..???
Old 08-20-2006, 08:26 AM
NeglectedField  is offline
Posts: 945  -  iTrader: (0)
As one might expect the strings have more tension to them, exactly how much I don't know, but some like it more than others.
Old 08-20-2006, 10:07 AM
Lefty Robb  is offline
I think the frets are spaced farther apart too, but I'm not exactly sure.
Old 08-20-2006, 10:37 AM
GilkyBear  is offline
Posts: 4,110  -  iTrader: (16)
The shorter or longer scale would have more tension?
Old 08-20-2006, 10:38 AM
longer
Old 08-20-2006, 10:39 AM
I would have thought the longer scale would have less tension on the strings. Interesting...
Old 08-20-2006, 10:45 AM
think about it, in order to get the same note in the same key on a longer string, you have to wind it tighter, thus more tension.
congrats on your 777th post btw...
Old 08-20-2006, 01:12 PM
eelblack2  is offline
Posts: 865  -  iTrader: (4)
Will be a pretty big difference in feel. I can feel the difference in scale between a LP and a Strat so I would imagine the jump from 25.5 to 27 would be even more pronounced. I string my Pauls with 11's and my strats with 10's or 9's depending - to help compensate for the difference in tensions.
Old 08-20-2006, 01:54 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
Yeah, you can feel the difference. A longer scale length gives you a more defined, piano-istic low end, especially if we're talking a 7-string tuned to B or below.
Once you et used to it, like anything, the extra string tension and slightly longer stretches aren't a big deal.
Old 08-20-2006, 03:43 PM
Does it mean than that it 27 would be harder to play.. i mean , let's say..faster runs and stuff..
I mean , streches doesn't seem to scare me..but the tension..it could be difficult for soloing maybe..?
And i was sure that i have red somewhere that tension is lesser in 27 than 25,5..
Old 08-20-2006, 04:08 PM
j.arledge  is offline
Posts: 1,803  -  iTrader: (30)
well 27 scale means that you have that much more tension on the strings . This means you can use smaller gauge strings to tune your guitar down and the strings not get all rubbery and floppy . 27 scale will more then likly be harder to tune to standard and still feel comfrotable playing due to the increase in tension. that is why guitars with 26.5 or 27 scale are called baritone guitars , they are between a bass and normal guitar .
Old 08-20-2006, 04:26 PM
Or,,i could stay in standard tuning, but use thinner or thicker strings..?
I guess thinner..?
Old 08-20-2006, 05:20 PM
Drew  is offline
Nah, you'll get used to it pretty quickly.
(as I sit here ripping up a 26 1/2" neck I've had for less than 2 weeks )
Old 08-21-2006, 02:36 AM
I guess thinner..?
stay in standard and use thinner strings to get up to standard tunning .
i personally like the other way , 24.75 scale
baritone guitar, gauge strings, string tension
Lesson 4: The Minor Scale - Part 4 of the Trilogy :) jem7vwh Guitar Lessons & Music Theory 19 12-11-2005 11:13 AM
Lesson 2: *The Major Scale - as requested :) jem7vwh Guitar Lessons & Music Theory 6 01-12-2005 06:02 PM
longer neck scale length rbjammin Other 7-string Guitars 14 06-25-2004 07:40 PM
String guage on short scale (i.e., Les Paul) vs. long scale gkelm Other 6-string Guitars (non-Ibanez brand) 2 01-09-2004 03:14 AM
About the XL scale length and jazz Jim Soloway Comments to Ibanez 2 11-25-2002 03:40 PM
