Set up after removing the neck..help please :-)
Discussion about any other 6-string guitars not made by Ibanez.
06-11-2005, 11:30 PM
TVE
Posts: 94 - iTrader: (
Hi,
I have recently removed the neck on my 75
Fender Strat
and I have never adjusted any setup before. What should I be doing?
Cheers
Tania
TVE
Find all posts by TVE
06-12-2005, 06:47 AM
jemaholic
Posts: 2,806 - iTrader: (
Re: Set up after removing the neck..help please :-)
Well, that could be tricky...why did you take it off if you don't know what your doing?
I'm sure you can find websites that can help.
jemaholic
Visit jemaholic's homepage!
Find all posts by jemaholic
06-12-2005, 07:29 AM
TVE
Because I needed to check what year she was.. dont worry i didnt do it just for something to do.
TVE
06-12-2005, 07:42 AM
Tom Gilroy
Posts: 1,747 - iTrader: (
When you put the neck back on always make sure that you don't over tighten te screws. I know you won't but its just a warning.
Tom Gilroy
Find all posts by Tom Gilroy
06-12-2005, 09:39 AM
damo7v
Posts: 1,150 - iTrader: (
those 70's strats are built like weapons. unless you changed your set-up in removing the neck, i would think you'd just put it back together and let it settle a little while once it's strung up to tension again.
if not, have a read through this:
fender's set-up guide for strats
all the best.
damo7v
Find all posts by damo7v
06-12-2005, 09:40 AM
jemaholic
Really not a big deal unless you've got the micro-tilt neck...just sounded wierd the way you worded the question....like oops, now what have I gotten myself into?....
jemaholic
06-12-2005, 09:30 PM
TVE
Thanx everyone.
Tom, havent adjusted the screws too tight, just tight enough not to be loose.
Jemoholic..cheers, can appreciated how this may have been read :-) LOL
damo7v, know what you mean by letting it settle down was tension tightened...she was going out of tune for a short while :-)
Yes I do have a micro tilt neck,
Cheers
Tania
TVE
06-13-2005, 02:51 PM
red5
Posts: 2,639 - iTrader: (
jemaholic
I have a microtilt neck on my G&L and I never use the feature. If I do, I have to raise the action....
red5
Find all posts by red5
06-14-2005, 12:49 PM
jemaholic
red5
If you ever do - - just make sure you loosen the
neck bolts
prior to adjusting the micro-tilt, or else you can mess it up....
jemaholic
06-15-2005, 03:40 PM
red5
jemaholic
If you ever do - - just make sure you loosen the neck bolts prior to adjusting the micro-tilt, or else you can mess it up....
Yeah, I'm not a setup noob
I tried using it, and I might be using it a wee bit (I forget) but i found the neck was tilted right anyway!
03:48 PM
red5
fender strat
neck bolts
parker are they neck thru
how can i tell thin or standard neck prs
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
how to narrow the fingerboard without removing it
cutting an original neck to become an all access neck
Zeroleet
Tech: Setup, Repairs and Mods
32
05-05-2005
10:08 AM
RG321 neck
MetalVoivod
04:36 PM
Removing the Neck on a 7DBK!!!
Chipiem
04:53 AM
Weird things on a 7620 neck: Need advice fast!!!
Gresh
02:03 AM
RG270 neck versus 570 neck? - how close are the wizard and w
BZ Beetle
05:59 PM
08:23 AM
