soloist
Discussion about any other 6-string guitars not made by Ibanez.
03-14-2006, 08:36 PM
metal gods
Posts: 40 - iTrader: (
soloist
In trying to choose between a
Jackson soloist
and a Ibanez prestige (rg2570) I've noticed there's quite a difference in price. Are the guitars really both top of the line and comparable to each other, or is the prestige line like a budget line below the j-customs?
metal gods
Find all posts by metal gods
03-14-2006, 08:51 PM
jaxadam
Classified Watchdog
Posts: 3,042 - iTrader: (
Re: soloist
Me personally: I'd go with the soloist, due to the fact that it's neck-thru, OFR, and Duncans. I also like the DK1; ebony, emgs, etc...
Between those two, the choice is obvious, but it's up to you, and I'm sure you'll hear all kinds of different opinions, too.
If you're looking to spend the kind of money on a soloist, I think there are a lot of different Ibanez that you should check out first.
jaxadam
Find all posts by jaxadam
03-14-2006, 10:32 PM
AARRGGHHH
Posts: 201 - iTrader: (
Re: soloist
I was under the impression that the top of the line stuff from Ibanez other than the sig stuff is the J-Custom and the top RGT models.
AARRGGHHH
Visit AARRGGHHH's homepage!
Find all posts by AARRGGHHH
03-14-2006, 11:01 PM
lyconxero
Posts: 1,469 - iTrader: (
Re: soloist
The RGT models aren't any "higher quality" than the other Prestige RGs. The main difference is that they are neck-thru guitars as opposed to bolt-on. J-customs are the highest end models that Ibanez currently makes but the regular prestige line is nothing to sneer at. If you can afford them both then I would simply make the decision on which is the most comfortable to you.
lyconxero
Find all posts by lyconxero
03-15-2006, 01:20 PM
rastachild
Posts: 720 - iTrader: (
Re: soloist
yeah,
neck thru
doesn't mean higher quality, which many people seem to believe for some reason. it's merely a different option in construction, tone and feel. there are advantages of each type and many players (such as myself) actually prefer the sound of a bolt on.
rastachild
Find all posts by rastachild
03-15-2006, 01:38 PM
Chud
Posts: 926 - iTrader: (
Re: soloist
Yeah, i've never understood why lots of people consider neck-thru to be better.
Given the choice i'd pick a bolt-on everytime... mainly because of practical reasons
Chud
Find all posts by Chud
03-15-2006, 04:57 PM
jim777
Posts: 8,943 - iTrader: (
Re: soloist
Both are fine guitars, but I'd go with the Soloist myself, especially if it's an SL1 with the S/S/H configuration (and NOT black). Put a maple board on the Ibanez and you'd change my mind though
jim777
Find all posts by jim777
03-15-2006, 06:12 PM
metal gods
Re: soloist
The soloist definately beats the Ibanez in looks; I'm not sure about the venerial disease finish on the 2570, I'd like to see it. Both guitars seem to play well but I wonder about how the ibanez would hold up through some good kit at high volumes, especially with the pickups not being bona fide dimazios. I really don't understand why they don't use real pickups on their 'prestige' line. I would prefere the soloist I think but there's also a lot I could spend $800 on (the difference).
metal gods
03-15-2006, 07:52 PM
jaken777
Posts: 517 - iTrader: (
Re: soloist
Depends on what type of music you do, but all the guitars mentioned here are good, if you play metal a lot go for the Jackson Soloist neck thru job, good for the money you pay, if not spend some mega bucks & go the J custom,
bolt on neck guitars don't sustain like a neck thru guitar but they do sound good with good pickups fitted or even a sustainer like some of Vai's guitars.
jaken777
Find all posts by jaken777
03-16-2006, 01:55 AM
gu1tar
Posts: 858 - iTrader: (
Re: soloist
Which Jackson soloist are you thinking about? The Soloist SL-2H or SL-1 are $2,000 and $1,800 respectively vs the 2570 which is $880. I've tried the SL-2H and SL-1 several times wanting to like them but although they are nice, they aren't any better to me (except the pickups) than the Prestige line. And I like the Edge Pro on the Prestige line much better than the OFR on the soloists. If you want a neck through guitar, the RGT220A or H are much better in my opinion and I think the soloists are overpriced. You won't know until you try them all out and see how they feel/play to you though.
gu1tar
Find all posts by gu1tar
03-16-2006, 11:30 AM
metal gods
Re: soloist
I'm looking at the sl2h rather than the sl1. Here the J-Customs are as just about much as the soloist. I can get the soloist for about $1600 shipped.
metal gods
03-16-2006, 12:01 PM
jaxadam
Classified Watchdog
Re: soloist
I like the SL2H. I also like the DK1. Have you checked that one out?
jaxadam
03-16-2006, 02:40 PM
metal gods
Re: soloist
I didn't play the DK1 but the SL2H and DK1 were hanging side by side. I could see clearly that the neck join wouldn't cut it, it's like a fender mex, just a big chunk of wood sticking out at the back. I was going to go for the DK1 originally but now I wouldn't even consider it. The Ibanez bolt on has a good neck join, I'd say it's almost as good as the jackson neck thru.
metal gods
03-18-2006, 07:54 AM
shredfreak
Posts: 809 - iTrader: (
Re: soloist
Soloists are great. I want one really badly!
shredfreak
Find all posts by shredfreak
03-18-2006, 11:21 AM
red5
Posts: 2,639 - iTrader: (
Re: soloist
Chud
Because they play metal and are ignorant to everything else most of the time, or their idea of a bolt on is a
squier strat
red5
Find all posts by red5
jackson soloist
neck thru
playing guitar
squier strat
what is the difference between jackson soloist sl2 and sl2h
how to spot a fake jackson soloist
jackson soloist professional whats it worth
Jackson USA Soloist SL2HT
Biaxident82
10:48 AM
FS: AX7521, Strato-thing, Soloist Pro
jim777
12:06 PM
F/S: 2004 NAMM Jackson Korina Soloist
Jackson Soloist
07:07 PM
Neck dimensions: 8570 vs. JAckson Soloist
Flanker
07:13 AM
Jackson soloist models
6StringGod
01:32 AM
03:54 PM
