Old 06-16-2005, 08:37 AM
wildchild247  is offline
Posts: 408  -  iTrader: (0)
Reviews: 5
Static noise coming from humbuckers
Hello
1. I have a jackson RR and the pickups create a very distinguishable static noise when I turn the volume up or down.
It is the most prominent when I hit open strings.
When I hold notes it seems fine but when the string rings out more noise.
The pickups are the jackson standards that come with it.
2. How do you replace the control knobs?
Thanks
Old 06-16-2005, 08:26 PM
Strat Man Dwight  is offline
Posts: 52  -  iTrader: (0)
Re: Static noise coming from humbuckers
Perhaps you could clean or oil the inside of the pots first.
I don't use spray contact cleaner because it can come into contact with guitar's finish. Not good.
A light oil can be applied directly inside the pot, with the control cavity cover removed.
Try that, moving the knob back & forth, if pots are scratchy.
Otherwise, replacing is ... removing knobs, removing pots, de-soldering, re-soldering.
Old 06-30-2005, 11:52 AM
Reviews: 5
I am not too sure of the technical terms
pot??
I have no idea
Sorry
Wildchild247
Old 06-30-2005, 11:57 AM
the.godfather  is offline
Posts: 3,593  -  iTrader: (12)
Might be an earthing problem.
Old 07-03-2005, 10:56 PM
dragsternj  is offline
Posts: 1,710  -  iTrader: (12)
Potentiometer
http://en.wikipedia.org/wiki/Potentiometer
Old 07-04-2005, 05:16 PM
red5  is offline
Posts: 2,639  -  iTrader: (0)
If the wood is protected by metal like a Les Paul, spray some silicon spray in the pots. Wipe excess spray off and it will not do any harm. Bet that will help!
Old 07-04-2005, 05:18 PM
red5  is offline
pot??
Yes, another term for marijuanna. It's a drug.... you smoke it!
cavity cover, control knobs, les paul
Van Halen & David Lee Roth Reunion? bpd111 Players, Bands, People, Music & Tours 86 04-17-2004 06:01 PM
Noise gate for rack: need high quality, reasonable priced SilverSurfer2 Gear and Equipment 3 01-09-2004 03:28 PM
Trem Bar Noise!!! Frankie Tech: Setup, Repairs and Mods 19 07-03-2002 12:00 AM
Annoying noise from Roctron Taboo Courjan Gear and Equipment 0 05-20-2002 10:51 AM
noise - ringing noise chip james JEM and Universe Guitars 6 01-15-2001 08:08 PM
