String Breaking - Musicman JP6
Discussion about any other 6-string guitars not made by Ibanez.
06-12-2007, 05:17 PM
Epicus Furor
Posts: 519 - iTrader: (
I keep breaking strings on my musicman jp6, literally 1 a day sometimes more. The strings ALWAYS break at the bridge, yet there seems to be no wear on the saddles? I use 9
guage strings
(i use 9's on my RG's and i rarely ever break them so it's very unlikley to do with my playing style). Any help would be much appreciated
Epicus Furor
Find all posts by Epicus Furor
06-12-2007, 05:21 PM
elcid
Posts: 8,720 - iTrader: (
Re: String Breaking - Musicman JP6
Check the saddles for burrs, thats more than likely your issue.
elcid
Find all posts by elcid
06-12-2007, 05:24 PM
Epicus Furor
Does that mean i have to replace the saddles or is there a way of smoothening them?
Epicus Furor
06-12-2007, 05:26 PM
elcid
It can be filed.
elcid
06-13-2007, 12:42 AM
TheOrangeChannel
Posts: 381 - iTrader: (
I've noticed D'Addarios doing that lately on the .10 sets...the plain strings almost come unwound...
TheOrangeChannel
Visit TheOrangeChannel's homepage!
Find all posts by TheOrangeChannel
06-13-2007, 11:49 AM
jim777
Posts: 8,943 - iTrader: (
Worst case you may be able to get EBMM to replace the individual saddle. They're a great company. Ask about this on their forum as well; it might be a semi-common issue that they're already aware of.
jim777
Find all posts by jim777
06-13-2007, 11:58 AM
jaxadam
Classified Watchdog
Posts: 3,043 - iTrader: (
jim777
Just make sure you "Contact Customer Service" first, or you will be flamed.
jaxadam
Find all posts by jaxadam
06-13-2007, 12:01 PM
elcid
Not to get too off topic here, but when I got my JP7 and the finish in the
neck joint
cracked twice in the first weekend customer service was very helpful. Although, I was a little disappointed that their first reply was "well, it doesnt affect the guitar at all, but if you want to send it in we will refinish it".
elcid
06-13-2007, 01:00 PM
Epicus Furor
I've just left it at my
local guitar shop
to get it looked at, at first look my tech said the design of the petrucci bridge is quite bad due to how steep the 'curve' is from the saddles where the strings run through, it's as if there's already tension there just when the strings are first put on which may cause them to break prematurely at the bridge. Anyhow he's going to file the saddles and see if that helps
Epicus Furor
06-13-2007, 01:27 PM
Demiurge
Posts: 883 - iTrader: (
The angle of the string coming over the saddle, as "bad" as it may be, shouldn't be enough to cause breakage. If that were the case, then most string-through hard-tail guitars and guitars with wrap-around bridges would snap strings left and right. When there's a burr, the angle certainly doesn't help, but shouldn't be a cause by itself.
Demiurge
Find all posts by Demiurge
06-13-2007, 01:29 PM
elcid
Not to mention there would probably be hundreds of other people having the same problem with thousands of posts here about it.
elcid
guage strings
guitar shop
local guitar shop
neck joint
convert 7 string to 6 string?
where to buy guitar string sin southampton
what distortion pedal can take guitars string 10-60
use a .016 for the 2nd string?
jpx 7 string?
Major Help! String Clamp Won't Budge!
Rekuss
Tech: Setup, Repairs and Mods
07:57 PM
Yet another poorly mixed song by your truly
IbanezroadstarII
33
03-16-2006
10:01 PM
String bending (low action)
blackpuppets
03:56 PM
Breaking strings on my 7DBK
henryb
03:16 PM
String Breaking at the Bridge.
Gex
05:03 PM
08:06 PM
