K, this is back to personal preference the way i see it. *But for bending on the g string it seems you could probably reduce it bout another 6-8 mm. *Mind you i made this calculation in about 30 seconds. *Measure the neck your gonna be working off of then bend the loosest string (usually the g) at about the 12th fret as high as you can without breaking it. *then try and see how much space there is between the string and the top of the
fret board.
* I'm not guaranteeing anything, best you get an eighth oppinion.
* Joel
