Wizard questions
Discussion about any other 6-string guitars not made by Ibanez.
04-09-2007, 12:40 PM
kenneth
Posts: 38 - iTrader: (
Wizard questions
I'm sure these questions have been asked before, so I apologize in advance. I did a quick search but couldn't find the exact info I was looking for. I just had a couple questions about the Wizard neck:
1) Is it possible (within reason) to put a 22-fret Wizard neck on a
Strat body
2) Is the Warmoth "Wizard" profile modeled after the Wizard II, and not the original Wizard?
Thanks for your help!
kenneth
Find all posts by kenneth
04-09-2007, 03:51 PM
jono
Posts: 5,003 - iTrader: (
Re: Wizard questions
Back in the day, when UK shops could sell spare
Ibanez necks
as a part of their inventory, it wasn't unusual for them to put 22 fret necks on a strat, or even take out the
neck pickup
and put a 24 fret neck on them, so yes it can be done.
I can't help with Q2, Sorry.
jono
Find all posts by jono
04-10-2007, 11:54 AM
CrossingStar
Posts: 1,046 - iTrader: (
You could put a Wizard SQUARE heel on a Strat body. That old heel is based on Strat specs. Just cut off the overhang at the last two frets.
Warmoths Wizard profile is slightly thicker than a real Wizard, but a bit thinner than a Wizard II.
CrossingStar
Find all posts by CrossingStar
04-10-2007, 11:57 AM
Dee
Posts: 8,514 - iTrader: (
That'd make it about 18mm, right? Sounds similar to the
Prestige Wizard
Dee
Find all posts by Dee
04-11-2007, 01:05 PM
kenneth
Thanks for all the info! I think you're right about the Warmoth "Wizard" neck - I checked the stats and did the conversion and it comes out to about 18.5 at the first fret, which like you said, sounds like it's a little bigger than the original Wizard, but still thinner than the Wizard II. Anyone know what the radius is like on those Warmoths? That flat, thin board on the original Wizard is my absolute favorite neck.
kenneth
04-11-2007, 02:00 PM
kenneth
It looks like the Warmoth necks come standard with their "compound" radius, which is described at 10 inches at the nut and 16 at the 22nd fret. But you can request a custom "straight" radius. They list some of the common guitar manufacturer radii - Ibanez is listed at 12 inches - but that doesn't sound right to me. Jackson is listed at 16 inches, which would seem closer to the wide, flat Wizard radius. Does 430mm convert to about a 16.9 inch radius?
kenneth
05-17-2007, 02:10 PM
brothersnowgone
Posts: 1,498 - iTrader: (
Reviews: 7
CrossingStar
So warmoth's with 24 fret extensions fit on old heel Ibanez's? If this is true I fear for my pocket book...
brothersnowgone
fret neck
fret necks
ibanez neck
ibanez necks
neck pickup
prestige wizard
strat body
warmoth neck
how to play on a wizard neck
What does a Wizard neck look like?
can you replace a wizard 3 tremolo with a floyd rose?
wizard ii is a jem neck
what's the difference in a universe and wizard 7 neck?
Jem555 Wizard neck?
Thared33
01:32 AM
RG 570 necks: Wizard or Wizard II
leclaw
07:32 AM
Wizard and Wizard II swap
sdhelter
10:47 PM
Can a wizard II neck be sanded down to a wizard?
Robert tyler
Tech: Setup, Repairs and Mods
03:51 AM
Altering Wizard II to Wizard profile?
TAorama
04:26 AM
11:15 PM
