Go Back   Jemsite > Guitars and Gear > Other 6-string Guitars (non-Ibanez brand)
Old 04-11-2005, 12:17 AM
napee napee is offline
Posts: 94  -  iTrader: (0)
Yamaha adjustable nut
Guys,
have a question here. I read in other threads here that Yamaha have a special kind of adjustable locking nut. The nut can be adjusted for height.
Now, I have one RGX-420S (2003 model, great guitar for the money btw). The nut have more screws than there is on my prestige ibanez. there's two big screws to keep the nut in place, plus 4 other smaller ones which i believe are to adjust that thingy.
i tried, but do not seem to be able to adjust it? how actually to adjust those?
Thanks.
Old 04-11-2005, 05:51 AM
Jemmm Jemmm is offline
Posts: 396  -  iTrader: (0)
Re: Yamaha adjustable nut
Shim it or grind it down. That's the options you have.
Old 04-11-2005, 11:45 AM
frankfalbo frankfalbo is offline
Posts: 1,760  -  iTrader: (13)
Whaa?!
If it's the Yamaha adjustable nut you don't have to shim it or file it. The reason you can't adjust it is because it's locked down right now. So you have to loosen up the screws that hold it in place, and then you should be able to adjust the others.
As a sidenote, they don't sound the best because they're just sitting on little screw tips rather than making strong solid contact, but that's just the open notes.
Old 04-11-2005, 02:00 PM
Originally Posted by frankfalbo
Whaa?!
hmmmm yeah, makes sense. that's kind of obvious doesn't it?
OK next time i change the strings i'll ty it again. thanks for the tips.
Bookmarks
locking nut
