Go Back   Jemsite > Guitars and Gear > Other 7-string Guitars
Old 01-13-2003, 05:04 PM
403 403 is offline
Posts: 70  -  iTrader: (0)
25 vs. 27 inch scale
what's the difference between these two?
Old 01-13-2003, 05:09 PM
Rich Rich is online now
Posts: 18,371  -  iTrader: (18)
2 inches
Old 01-13-2003, 05:19 PM
403 403 is offline
Originally Posted by Rich
2 inches
would you believe me if I told you I was expecting the exact reply?
no really, why is the 27inch better (as I heard) on the 7string?
Old 01-13-2003, 06:28 PM
Jim Soloway Jim Soloway is offline
Posts: 551  -  iTrader: (1)
The low string on a 7 string is basically a bass string on a guitar length scale. There not really enough tension for the string to fully articulate. The added two inches provides a tension which is much better suited to a low A (or B) which results in much clearer, more precise note. The other strings can be maintained at normal guitar tension by going don one gueage of strings and even those strings seem to ring much more evenly.
Old 01-13-2003, 08:34 PM
Sevenstringer Sevenstringer is offline
Posts: 341  -  iTrader: (1)
So sorry to hear that Rich, haha
Old 01-15-2003, 12:16 AM
Benno Benno is offline
Posts: 35  -  iTrader: (0)
Can you just buy one of these 27 inch necks and fit it onto your standard guitar? Do all the 27 inch ibanez necks fit ibanez bodies?
Old 01-15-2003, 12:21 AM
jemsite's Avatar
jemsite jemsite is online now
Administrator
Posts: 11,878  -  iTrader: (5)
Images: 11
I don't believe they are a retrofit. The nut to bridge length is 25.5" vs 27". The bridges should be slightly offset to compensate. The spacing between frets is also different.
Doing a neck swap should render the guitar impossible to intonate... glen
Old 01-15-2003, 12:22 AM
The bridge on an XL is moved toward the tail so that the neck isn't "that" much longer than a 25 1/2" scale neck.
Old 01-15-2003, 12:24 AM
Yea, that too
Old 02-04-2003, 12:07 PM
403 403 is offline
heard the strings break more often on the 27 scale than on the 25. true?
also, why is it that the 7421 sold better than it's xl scale sister - 7421xl?
(haven't tried the xl neck and have to order before I try so I have to make sure I wouldn't end up with something I wasn't comfortable with)
Old 02-04-2003, 08:54 PM
Two hands31 Two hands31 is offline
Posts: 8,427  -  iTrader: (0)
I think you just answered your own question. It's mainly because people go "Longer neck?...I dunno..." and just keep walking. The same way most people go "An extra string?...I dunno..."
Old 02-05-2003, 06:27 AM
403 403 is offline
that's because I live in a sh*thole country - but I am sure people can try it out somewhere in western europe or USA just as they can try the rest of the seven stringed guitars (Ibanez for instance)
btw. two hands31 what guitar do you have?
  #13
Old 02-05-2003, 07:36 AM
Squire Strat w/ DiMarzio Super Distortion I put in the bridge.
Schecter Revenger-7
  #14
Old 02-05-2003, 08:44 AM
403 403 is offline
Schecter Revenger-7
the schecter - is it custom or diamond series?
how do you like it?
had my eyes on an omen 7, only problem with it is that it has no floating bridge (correct me if I'm wrong )
  #15
Old 02-07-2003, 10:23 AM
Schecter Revenger-7
how do you like it?
I'm not sure about the floating bridge thing, but the Revenger-7's a now discontinued, very low-end Diamond series, hardtail 7-string, but it's a great, yet simple, guitar. I'd recommend Schecter to anyone really, good guitars, at least the hardtails, I can't voutch for their floating/whatever bridges.
Bookmarks
dimarzio super distortion, ibanez neck, ibanez necks, schecter revenger, squire strat, super distortion
