Old 12-26-2002, 06:19 PM
Two hands31  is offline
Posts: 4,989  -  iTrader: (0)
7-String Gauges
Ok, I'm looking for a set of strings for my brand new 7-string, cuz my lowest strings are not quite thick enough. I play mostly in standard, or drop-A, but I do quite a bit of down a whole-step too. I think they've got it strung with 10-54 right now, but I'm not completely sure. I just know that everything up to the 6th and 7-th string are ok, but the last two could use a bit more to them.
Old 12-26-2002, 06:24 PM
trajectory fish  is offline
Posts: 394  -  iTrader: (0)
I reccomend at least a .058 for the B string.
Old 12-26-2002, 06:41 PM
Yeah, I was thinking of going with a .060 even. Is that too much in standard tuning? What guages should I use for the other 6? (probably 10-??)
Texter  is offline
Posts: 839  -  iTrader: (0)
Right now I'm using a .56 ...it's doing well for a year now Maybe I oughta put on a new one...Sounds like you are ready for a .60
Old 12-26-2002, 10:18 PM
Dylan7620  is offline
Posts: 636  -  iTrader: (1)
10-60, nice tension for chunky not mucky chords in A. but u can still do some string bendin.
Old 12-26-2002, 11:30 PM
Jim Soloway  is offline
Posts: 518  -  iTrader: (1)
12 - 72 on a 25.5 inch scale, 11-72 on the 27 inch XL scale. Standard tuning E-E and a low A.
Old 12-26-2002, 11:56 PM
brianboros  is offline
Posts: 85  -  iTrader: (0)
I use .10 - .60. I'll buy a .10-.52 set and an extra .60 (sometimes .62). works for me. Tuned to Standard.
Old 12-27-2002, 12:36 AM
Cool, that's exactly what I was thinking of. Getting a thin-thick (10-52) set, and buying a 60 separate. Thanx! Can't wait to see the guitar shop guy's reaction. Not too many 7-stringers around here.
Old 12-28-2002, 11:29 AM
guitarkatana  is offline
Posts: 635  -  iTrader: (0)
I just buy regular 10-46 6 string sets, then I buy a single .60 string. It works great for low B.
Old 12-28-2002, 04:53 PM
Stupid guitar shop didn't have a .60 that wasn't a bass string. I may settle for a .58, but I'm gonna do some searching around to other shops in town (though I doubt they'll have them). So instead, I bought a 7-string set of D'Addarios (only 7-string sets they had) in the same guages I had on it already (just for now, it needed new strings anyways, and a decent setup) 10-56. The action is great on this thing though, 3mm across the board. Best part is, 7-string sets are $7.99, and 6-string sets are $6.49, the guy at the counter isn't used to 7-strings apparently, cuz he just glanced, saw "D'Addario", didn't see the "7-string" label, and charged me $8.00 ($6.49 + tax).
Old 12-28-2002, 05:25 PM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
GHS makes .010 to .060 as a standard set. You can get them at juststrings.com. These are the ones i use.
Old 12-28-2002, 05:29 PM
Wound  is offline
Posts: 312  -  iTrader: (0)
I've always just gotten a bass string for the bottom... started with .060, then went to .065 then to .072 or .070...don remember, but went back to .065. I have never seen normal guitar strings thicker then .056...heh
Kim
Old 12-28-2002, 09:15 PM
Kim
I use D'Adarrio nickel crome round wonds for my low string. Thet go all they way up to an 80 in standard guitar format. They sell them at as singles at www.juststrings.com. Thomastik Infeld made a great .72, much better than the D'Adarrio. I tested the prototype and then they decided not to bother releasing them. Too bad really. It was a great string.
Old 12-28-2002, 09:24 PM
Is it possible to use a bass string? Keeping in mind this is a hardtail guitar, and I won't be cutting off the ball end. Will a .058 be good enough? I may end up ordering a bunch of those sets Darren linked to (thanx btw).
Old 12-28-2002, 09:30 PM
Another option would be to get a set of Zakk Wylde low-tune Boomers, which go .011 .014 .018 DY36 DY52 DY70, and slap a .009 on top. The cool thing with that is you'll have an unwound D string.
I don't think a bass string would do any harm, as long as the ball end will fit through the ferrule in the back, and the string itself fits through the loading hole in your bridge, the nut and the tuning machine. Keep in mind that if you do go way up in gauge, you're going to have to get your nut slots widened a bit. I wouldn't recommend going lower than a .060.
I wanted to put the bottom four strings of a 5-string set on my fretless P-Bass, but the thick string diameter wouldn't fit through the hole in the Badass II bridge.
fixed bridge, guitar shop, zakk wylde
