Other 7-string Guitars
7 string + GK-2A question
7-string, 8-string & extend-range guitars guitar talk only here. All makes and models except the Universe.
07-12-2004, 10:26 PM
RexGtr
Posts: 20 - iTrader: (
Ok, we know there isn't a 7 string guitar synth, only 6 strings that I'm aware of.
My question is what do you guys prefer on a 7 string, the GK on the E thru E or the B to B?
RexGtr
Find all posts by RexGtr
07-13-2004, 04:09 AM
Two hands31
Posts: 4,989 - iTrader: (
I've heard most people like E to E as they say it tracks better or something, and they use the high notes more. But then, Amir Derakh of Orgy uses Roland GK-2A pickups on his 6-strings tuned down to B without any trouble, and I've heard of others using theirs on the B-B setup of a 7-string as well.
I guess it comes down to which strings you'll be using more often with it. If you want those five extra low notes, go for the B-B setup, but if you want the higher notes, go for the E-E.
Two hands31
Visit Two hands31's homepage!
Find all posts by Two hands31
07-13-2004, 09:29 AM
Scott of Actual Time
Posts: 363 - iTrader: (
Two hands31
I've heard most people like E to E as they say it tracks better....
it does. the reason is because the roland midi pickups track more accurately on smaller
gauge strings
. the bigger the strings get, the worse the tracking is.
Allan Holdsworth
on his synthaxe, a completely midi guitar, uses .008s for all six strings to get really good tracking.
so you can try B-B if you want, but it won't track as well.
Visit Scott of Actual Time's homepage!
Find all posts by Scott of Actual Time
07-13-2004, 06:00 PM
RexGtr
Thanks, good points about Roland hex pickups tracking better with lighter gauges. I tried that after reading it on the net, it really does track faster.
A neck with .008's on every string would be of no use other than midi work?
I wonder would each string be tuned to the same note?
(which note?C4?) (Note triggering is gets transposed to what ever tunnings)
Do piezo midi bridges vary in tracking with different gauges?
For now I'm gonna try double sided tape so I can experiment, either way I'm gonna be missing one string of expression but I'm leaning towards E to E .
RexGtr
07-14-2004, 01:46 PM
Random Man
Posts: 7 - iTrader: (
Have any of you guys tried the Yamaha G50 + pickup midi setup? Anyone know how it compares to the Roland?
Random Man
Visit Random Man's homepage!
Find all posts by Random Man
07-14-2004, 03:56 PM
Two hands31
The synth-axe which he uses all .008s on isn't actually a guitar. In fact, you don't even pluck the strings. In fact, it doesn't even have a synth pickup on it. It sends a small current down the strings, so when you push the strings down on the frets, the frets complete the circuit and it knows what fret you're playing. So it doesn't really matter how the strings are tuned.
Two hands31
07-15-2004, 08:59 PM
analogcreature
Posts: 179 - iTrader: (
trey azagthoth from
Morbid Angel
has a 7 string GK-2A for his custom 7 string ibanez
analogcreature
Find all posts by analogcreature
07-15-2004, 10:22 PM
frankfalbo
Posts: 1,875 - iTrader: (
Why not make a small "U" shaped channel that acts like a track, so you could slide the GK2 back and forth between the two positions? If you do it right, the pressure could be what holds the GK2 in place so that you just push it over. Or you could use pins to lock it in place through one or both of the mounting holes.
p.s. I will design and build it for one thousa..no, wait..two thousand dollars.
frankfalbo
Find all posts by frankfalbo
07-16-2004, 03:16 AM
The_Grindfiend
Posts: 668 - iTrader: (
Good idea. Have you seen that one bass (that I conveniently forget who makes) that has one big pickup mounted on the bottom side (closest to the controls) that you can sweep all the way across to bridge or neck?
The_Grindfiend
Find all posts by The_Grindfiend
07-19-2004, 07:03 PM
Serratus
Posts: 491 - iTrader: (
I'm not sure how that would work, because with the Roland synth you have to setup the sensitivity of each string within the synth itself, and this may get messed up if you suddenly changed strings (unless you were happy to re-calibrate the synth unit after each adjustment of the pickup). It may be fine, but just a thought. And if it's any help, I've always used a Gk2a on the top 6 strings (E-E), as most of the sounds you need on a synth I think tend to be higher (pads, melody lines, piano, etc). Also it's kind of irrelevant as you can setup each string differently for each patch on the synth (with regard to pitch), so if you want a patch with low notes then move the sound down an octave in the software and play it a bit higher - you then get the benefits of quicker tracking, but with the lower register.
Serratus
Visit Serratus's homepage!
Find all posts by Serratus
07-23-2004, 07:31 AM
Polaris20
Posts: 1,418 - iTrader: (
Why don't you just get the Graphtech Ghost system? If I get a 7, it'll either be a Carvin DC727 with hardtail, an RG7321, or an imported RG15271 from Ishibashi.
Either way the thing is going to get taken right in to get the midi saddles put in. Then it won't look cheesy, and it'll track fast.
I plan to get this for graduation
Polaris20
Find all posts by Polaris20
07-23-2004, 12:43 PM
Two hands31
Polaris20
Well, the problem with that is, the system is still only designed for 6-strings, so you have to combine the signal of two of your strings, which means you can't use them both at the same time.
Two hands31
07-23-2004, 08:24 PM
brianboros
Posts: 85 - iTrader: (
I agree with Serratus, I was going to say that.
I'm going to get RMC saddles for the E to E strings on my seven [fixed bridge]. Also depending on your set up, Low notes may not sound as hi-fi through a guitar amp with synth sounds [depending on the sound your after and patch used]
brianboros
Find all posts by brianboros
07-23-2004, 11:47 PM
RexGtr
I use a home high fi setup so my guitar synth sounds are clean and clear.
A 400w active sub and two behringer truth active monitors.
Also I run everything else thru these, my keyboards, vocals, bass...
That's a great idea of making a harness that allows you to move the GK2a saddle between positions.
RexGtr
allan holdsworth
fixed bridge
gauge strings
morbid angel
convert 7 string to 6 string?
where to buy guitar string sin southampton
what distortion pedal can take guitars string 10-60
use a .016 for the 2nd string?
jpx 7 string?
02:04 PM
