Old 04-13-2001, 11:17 AM
Noodles  is offline
Posts: 531  -  iTrader: (0)
7-String Neck Specs - As found on www.ibanez.co.jp
* * * * * * * * * * * * * * * * * K7 * * * UV * * *Wizard7 Wizard7P
Width@ nut * * * * * * * *48mm *48mm * *48mm * * 48mm
Thickness@ 1st fret * * 19mm *20mm * *19mm * * 19mm
Thickness@ 12th fret * 21mm *21.5mm *21mm * **21mm
Width@ 21 fret * * * * * 65mm * 65mm * *65mm * * 66mm
Wizard7P=Wizard7 Prestige
Hope this helps.
Old 04-15-2001, 08:23 PM
RageOMatic  is offline
Posts: 2  -  iTrader: (0)
7-String Neck Specs
I think the main difference between the UV neck and the wizards is the shape of the UV. You got a bit more to grip on, making it easier to play. the wizard necks are a bit too thin imo.
Old 09-10-2001, 03:46 AM
BlackElk  is offline
Posts: 8  -  iTrader: (0)
7-String Neck Specs
Actually, the thickness of the K7 neck is 21.5mm at the 1st fret, 23mm at the 12th.
Old 09-10-2001, 11:48 PM
Noodles  is offline
7-String Neck Specs
Those were the spec off the site in april. If thats the case hopfully the changed it.
Old 09-12-2001, 05:17 AM
BlackElk  is offline
7-String Neck Specs
Yeah, I noticed the dates of the posts after I replied.
Sorry 'bout that.
It looks like this forum was pretty active until a few months ago, then went quiet...
