Old 09-07-2008, 11:01 AM
JohnnyRG1527  is offline
Posts: 99  -  iTrader: (0)
7621 neck dimensions
Hi, i've brought a 7621 neck off E*** and i trial fitted it to a 7321 body i'm refinishing for somone (the necks not going on that body, just wanted to see what it looked like ) and the neck pocket on the 7321 is about 2mm too small. i measured the neck heel and it's 66mm. is this common for necks and pocket sizes to vary? i understand the 7321 is korean and 7621 is japanese so maybe this is the reason? I'm gettind a body custom made for the neck anyway so it shouldn't be a problem, i'm just curious.
Old 09-07-2008, 12:06 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
Re: 7621 neck dimensions
well, the obvious difference is 7321 = fixed bridge and 7621 = trem
I believe they are both the same width at the nut although im sure the 7 string knowledge community may tell me otherwise..
Old 09-07-2008, 12:39 PM
hirah  is offline
Posts: 135  -  iTrader: (4)
Reviews: 3
actually, the 7621 is a fixed bridge also. but it seems that alot of korean necks are different. maybe so they couldnt be sold as a japanese rg if the necks are swapped.
Old 09-07-2008, 04:02 PM
thanks for the replys guys, and yes it is a fixed bidge neck. 3 piece off a 99 MIJ model.
RG2228 Neck Dimensions ibanezrocker61 Other 7-string Guitars 11 06-05-2008 10:56 PM
Voyager / RBM neck dimensions antonio_das_cruzes Other Ibanez Guitars (including Premiums) 2 02-07-2007 08:48 PM
Maverick neck dimensions RGR570 Other 6-string Guitars (non-Ibanez brand) 4 01-18-2007 06:16 AM
Question about neck dimensions TimS Tech: Setup, Repairs and Mods 0 01-01-2007 01:12 AM
RG1527 Neck Dimensions Vs Universe Neck Dimesnions Munkipuss Other 7-string Guitars 6 05-05-2005 08:53 AM
