Old 02-09-2007, 05:33 AM
axechain  is offline
Posts: 18  -  iTrader: (0)
& string baritone string gauge
the thing is that i`m modding my 7321 and gonna put a custom 7 string baritone 27" neck with reversed headstock in it, so the question is why people put so thin string for standart 7 string B tuning (strings like 68 - 70) for baritone
Old 02-09-2007, 05:35 AM
axechain  is offline
Re: & string baritone string gauge
...and what string gauge had the Ibanez rg 7 string baritones like 7421XL
Old 02-09-2007, 07:13 AM
rgk7  is offline
Posts: 156  -  iTrader: (1)
I heard that it won´t work what you are planning to do with that neck...
you would have to move your bridge too.
I think a .70 is ok for a baritone
Old 02-09-2007, 09:00 AM
Roland  is offline
Posts: 617  -  iTrader: (0)
What? You've got your things ass backwards all the way. First off, what are you going to tune it to? Second, .068/.070 is NOT thin, it's rather thick. Third off, an RG7421XL neck will not work without moving the bridge as well. You're gonna have to calculate exactly how much distance one or two extra frets would add, and it would not add up to "27 in either case.
Some guy had a custom neck made for his S7, which brought the total scale length up to "28 5/8, it basically added two frets to the nut-end of the fretboard.
Old 02-09-2007, 09:55 AM
axechain  is offline
sorry mistyped THICK is the right word and i whant to tune it in standart B or Bb
Old 02-09-2007, 10:12 AM
Roland  is offline
Lol, then that explains a lot. Well, I don't know of people who use that kind of measure on a baritone, but if you're going to tune around the A/B-area, .060-.056 should be just fine around "27 or "28.
Old 02-09-2007, 07:33 PM
Aris_T  is offline
Posts: 597  -  iTrader: (0)
The string gauge depends on how you're going to tune. As Roland said 56-60 is ok for the A/B area. IMO you don't have to mod your guitar to a baritone for this kind of tuning, unless you want to go even lower (to G probably).
reversed headstock
Your string guages are wrong! Dino Gear and Equipment 238 05-05-2008 07:34 PM
other guitar forums SandmaN211 Off-topic / Miscellaneous 38 12-27-2006 12:31 AM
Dave: What gauge string do you use for the acoustic seven string? Ekim Dave Weiner Official Forum Archive (SEE NEW LOCATION) 6 09-18-2005 08:30 PM
strings for my new 7 string baritone (1077xl) skattabrain Other 7-string Guitars 5 11-06-2004 03:17 PM
Fatty-My 7 string baritone hollowbody ATDVSBL Other 7-string Guitars 19 06-22-2003 04:09 AM
