Other 7-string Guitars
Body size: 6 vs 7
7-string, 8-string & extend-range guitars guitar talk only here. All makes and models except the Universe.
07-01-2005, 12:47 PM
aj_foes
Posts: 152 - iTrader: (
Body size: 6 vs 7
hello ppl. I'm just curious.
Is the size of a typical 6-string RG the same as a 7-string RG?
aj_foes
Find all posts by aj_foes
07-01-2005, 12:49 PM
Flobanez
Posts: 5,513 - iTrader: (
Re: Body size: 6 vs 7
I always thought so. The routings are different. I know that.
Flobanez
Visit Flobanez's homepage!
Find all posts by Flobanez
07-01-2005, 12:51 PM
Drew
Posts: 4,538 - iTrader: (
identical.
Drew
Visit Drew's homepage!
Find all posts by Drew
07-01-2005, 01:00 PM
aj_foes
Drew
identical.
oh cool! ok, since that they're identical, let say i have an RG with pickguard, an a cavity underneath.
if i do some routings on the neck pocket, to fit a 7-string neck, and also routings for the 7-string floyd-rose bridge, plus a new pickguard that fits 7-string humbuckers and singlecoil, ...then i'll have a 7 string, right?
but, considering the cost and time involved, i just might buy a new one LOL!
it's just me, n all this ridiculous ideas of mine :P
aj_foes
07-01-2005, 01:11 PM
SidewinderINC
Posts: 44 - iTrader: (
you could do that i guess
ive always wondered something quite similar.. but the other way round.
ok, i'm buying a £550 Prestige 6 string RG, but i also want a 7 string guitar...
could i spend that £550 on a 7 String Prestige RG (or add a little more if necesarry) and then if i feel like playing just a 6 string remove the low B ?
or would that mess with the trem?
sorry for hijack
SidewinderINC
Find all posts by SidewinderINC
07-01-2005, 01:18 PM
Serratus
Posts: 491 - iTrader: (
aj_foes
I think you're biggest problem would be that you would have to move the trem post anchors to fit the wider trem (ie, remove them, fill the holes and re-drill which could be awkward). If it were a six
string fixed bridge
model body then I think it would be easy to rout the body for a 7 string neck, pickups and trem. The body shapes are pretty much identical - I've had an RG7 body sat on top of an RG6 body and they are the same apart from a slight change in shape around the edges of the neck pocket - not enough to worry about IMO.
Serratus
Visit Serratus's homepage!
Find all posts by Serratus
07-01-2005, 01:19 PM
aj_foes
yup, you'd have to retune. pretty inconvenient.
plus, you could have some problems if you need to fret the low E string with your thumb or whatnot, i guess.
but i think it's pretty awkward to actually play the 7-string as a 6-string, with the low B string absent, because of the neck width, don't you think?
aj_foes
07-02-2005, 07:54 PM
timi_h
Posts: 1,104 - iTrader: (
SidewinderINC
sorry for hijack
just get a 7, then u can just ignore the low B when its not needed!!
timi_h
Find all posts by timi_h
body shape
fixed bridge
fixed bridge model
string fixed bridge
what size pick does zakk wylde use
guitar body swirl how to
what necks will fit into an s body ibanez
what happens to your body before you die
Which DiMarzio is bestl for basswood body
RG body vs. RG7 body - size difference?
chilln2music
02:40 AM
JEM and Universe body, same size ?!
Babook
01:37 AM
Known history of Guitar.. (lots of people have it wrong) - a
vwall
Archived Topics and Common Questions - GO HERE FIRST
01:44 PM
vwall
02:20 AM
04:07 AM
