Old 04-10-2009, 08:44 PM
EvoGiant  is offline
Posts: 355  -  iTrader: (2)
Coil tapping a 7620
i have an RG7620 with the original switch. i want different switching options. heres what i want:
1 bridge hb
2 Bridge coil cut to SC
3 Bridge and Neck HBs
4 Neck coil cut to SC
5 Neck HB
can i do that with the stock switch or do i need to use a super switch?
Old 04-14-2009, 01:03 PM
shotgunndunn  is offline
Posts: 8  -  iTrader: (0)
Re: Coil tapping a 7620
You can use a 3-way switch and a Push/Pull pot for coil splitting. If you don't want to do that, I can come up with something for you. I'll get back to you a.s.a.p.
shotgunn
www.shotgunnmods.net
shotgunn@shotgunnmods.net
Piezo's for your Ibanez Lo Pro, Edge Pro bridges!!!
forgot to subscribe
Old 04-14-2009, 01:15 PM
shotgunn
With this wiring you'll actually have 6 options. bridge hum, both hum, neck hum, bridge single, both single, neck single.
Old 04-15-2009, 12:10 AM
EvoGiant  is offline
thats how i have my tele set up. i was just wondering if the stock ibanez switch would allow it.
i put a superswitch in and im good now. thanks for the help though.
has the RGT 42 coil tapping? schmintan Other 6-string Guitars (non-Ibanez brand) 5 01-27-2009 11:10 AM
Has anyone tried coil-tapping an Evo 2? shreddersymphony Pickups & wiring 7 03-11-2008 04:49 PM
Coil Tapping Jem Humbuckers TremoJem JEM and Universe Guitars 6 01-11-2007 12:56 PM
Coil Tapping Jem Humbuckers TremoJem Pickups & wiring 0 01-10-2007 07:54 AM
Coil tapping the evo's on my 7vwh - can it be done? darthpolster JEM and Universe Guitars 1 03-19-2002 12:17 AM
