Old 10-05-2005, 12:12 PM
JN777  is offline
Posts: 184  -  iTrader: (0)
Custom 7 need help with woods
Hi im planning to order a custom seven with a luthier here in Mexico
This would be the guitar
Rg Shaped body and ibanez headstock
Neckthru construction
Neck:maple with 2 Purple heart stripes
Fretboard: Ebony with one inlay at 12 fret
Body wings: Mahogany with a top of?? suggestions?
a pyramid inlay like in the universe
Clear finish
Hardware:
Pickups: emg 81-7 bridge 707 neck with emg expander, already ordered.
Tuners: Sperzel Locking
Fixed Bridge
What do you thing about it. need some recomendations on woods. i would like some dark woods especially for the neck i would like something different from maple.
Old 10-05-2005, 12:18 PM
King Knall  is offline
Posts: 2,445  -  iTrader: (0)
Re: Custom 7 need help with woods
You'll have to know what type of music you play to have a better understanding of tonewoods and their tonal properties. You could always use a Mahogany neck if you want it darker, but its usually less stable than maple. Macassar Ebony would also be what you're looking for. As for the top, if you want a slightly brighter sound, then get a solid maple top, flamed or quilt if you like the wood grain . I can't comment on other tops, because maple has been the only one I've tried so far. Anyway my 2 sen.
Old 10-05-2005, 12:19 PM
Progdude  is offline
Posts: 250  -  iTrader: (0)
mahogany! Thats what LPs are made out of.
Old 10-05-2005, 01:45 PM
JN777  is offline
neck: mahogany with 2 purpleheart stripes fretboard Ebony. Would this be stable or do i need harder woods?
i play alternative music in my band, some kind like incubus.
But i also would like to play with this guitar something heavier, like korn, brujeria, FF, some progresive stuff also.
For the top, im only going tu use it on the wings not the neck, cuz i want the purple heart stripes shown on the front and back of the guitar, like in the RGT220
Old 10-05-2005, 05:03 PM
jim777  is offline
Purple heart is used to make bridges; it's as hard as you'll ever need.
Old 10-05-2005, 06:00 PM
JN777  is offline
Ok so thats it
Neck: Mahogany with 2 Purple heart Stripes
Fretboard: Ebony
Old 10-05-2005, 06:54 PM
7 Dying Trees  is offline
Posts: 1,708  -  iTrader: (4)
Ever since taking delivery of the custom with swamp ash wings I've thought about how they'd sound on a 7, so if you want something really special try swamp ash for the wings and slap a maple top on. You basically get a nice breathing open sound with the ash and some brightness on top. On the 6string everything sounds really smooth and just sings, so that may be an option looking into.
*swamp ash, before anyone points out, is actually just ash but grown in a swampy enviroment/wet enviroment that makes the wood more porous, and to some, more tonefull across the frequencies.
Otherwise I'd suggest trying mahogony wings, but do brighten that up with a maple top!
Old 10-07-2005, 01:06 AM
JN777  is offline
i think ill try the mahogany wings with some top, maybe spalted maple, or a dark wood(any recomendations?)
Today i received the Emg pickups !!! yeah!!! im happy an emg 81-7 one 707 and a expander. Those pickups looks amazing!!
So next step taking my custom order with the luthier.
Old 10-10-2005, 11:46 AM
JN777  is offline
Re: Custom 7 need help with bridges
I need a bridge wich one is the best for you?
this one is $22
http://guitarpartsdepot.com/Merchant...gory_Code=7SGP
The hipshop one $80
http://www.hipshotproducts.com/7string/7string.htm
allparts one $65
Old 10-11-2005, 02:28 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
Gotta second 7 Dying Trees here - mahogany is a bodywood without a lot of true depth, a lot of lower mids, and not a heck of a lot of brightness to it. In a seven, you want great bass coupled with excellent clarity. As such, mahogany (which isn't at all bright, nor overly "detailed" sounding) is really far from ideal.
I've currently got a UV7PHW and a RG7CST, and of the two, the UV is overall the tonally surperior one, IMO. the CST is a great rhythm guitar, and sounds phenominal clean, but for heavy low-B riffing is no match for the UV, and also can't touch the UV as a solo instrument - to me, it sounds more balanced across its entire spectrum than the CST. Don't get me wrong, they both sound phenominal, but if I had to have just one, I think basswood works better for a 7 than mahogany, even if mahogany is better in certain applications.
I'd STRONGLY recommend a brighter tonal wood, like ash or alder.
Old 10-11-2005, 03:26 PM
Serratus  is offline
Posts: 491  -  iTrader: (4)
this one is $22
The hipshop one $80
allparts one $65
If you want a quality instrument then go for the hipshot - I have two of their bridges (one 7-string and one 8-string) and they're both great - made really well and no problems. The cheaper bridges might be okay, but you may have problems longer-term - ie, they may corrode quicker or the saddles may wear and cause string breakage, etc.
Old 10-11-2005, 08:56 PM
Very true. Mahogony on it's own would really "dull" the guitar. Great for rythm, but If you want to go down the mahogony road I'd seriously put a maple top on (ala Les Paul) to brighten up the sound.
Ash would be a good option, and research the mythical "swamp ash" (i had a guitar builder lecture me that there was no such thing as swamp ash, and that it was just ash grown in a wetter enviroment, (ie, a swamp, so go figure ) and the 6string I have with this has excellent clarity and even frequency response across the whole register, it sings basically . Why the "swamp ash"? It has a slightly different more porous structure that just has a fukller frequency response.
Still, even with the ash I would recommend a maple top, as this will brighten up the guitar. You can always make it thicker through the amp bass wise, as long as all the frequencies are clear. Also, maple tops mean gorgeous flame and quilted patterns to make the axe look truly droolworthy
In fact, possibly look up some popular wood choices for basses!
Getting the right wood is a nightmare when you are exploring more exotic ones as there are no stock guitar references, but if yu want something that is truly custom and unique it is recommended!
Old 10-12-2005, 05:33 PM
jim777  is offline
Swamp ash comes from the part of the ash tree that is actually submerged under water. So, it should be possible to get ash and swamp ash from the same tree.
Old 10-12-2005, 06:33 PM
guitarshredder7  is offline
Posts: 610  -  iTrader: (0)
get it in koa!
Old 10-12-2005, 09:04 PM
Chris From Singapore.  is offline
Posts: 462  -  iTrader: (0)
Here's a page with some good information on wood combinations.
http://www.suhrguitars.com/wood.htm
Hope it helps, good luck with your custom
amp settings, custom guitar, fixed bridge, flame maple, frank falbo, les paul, mesa nomad, pyramid inlay, quilted maple, sperzel locking, string breakage, swamp ash
'Custom' Ibanez Shredder stuck in the 80s JEM and Universe Guitars 40 05-16-2007 03:01 PM
blaze custom vs custom 7 (also called NEW 7) ibanez7addict Other 7-string Guitars 13 11-14-2004 11:04 PM
Totally customizing the RBM1 or a custom PGM? RCB Other Ibanez Guitars (including Premiums) 1 10-06-2004 12:27 PM
Ibanez website - Custom 7420? Extremely custom Polaris20 Other 7-string Guitars 2 05-01-2002 05:38 AM
USA Custom "Exotic Woods" Series - My new obsession! vaijem777 J-Custom, USA Custom & Prestige Ibanez Guitars 40 12-07-2001 11:43 AM
