Old 01-21-2008, 02:15 PM
Mr.WizardNeck  is offline
Posts: 917  -  iTrader: (0)
Drop F tuning on a 7 string?
I was thinking of getting a 7 string and tuning the normal 6 strings to C and then dropping the biggest one down and was told it would be an F. True? If so, how would this sound, has anyone done it before and what guage would be recommended?
Old 01-21-2008, 02:29 PM
Andelusion  is offline
Posts: 1,373  -  iTrader: (4)
Re: Drop F tuning on a 7 string?
I think you'd want a baritone to be honest, that low string is going to be VERY flabby.
Old 01-21-2008, 04:07 PM
jim777  is offline
You could make it F, but if you kept the relationships the same it would be G.
Old 01-21-2008, 04:26 PM
Roland  is offline
Posts: 617  -  iTrader: (0)
You can't make a good-sounding F-powerchord. The inherent lowness of the note causes the fifth (in this case, the C) to overpower the fundamental F, regardless of how good 'a guitar you have. Single-notes are okay, but powerchords just turn into a haze.
The more sensible thing would be to tune to G, as previously mentioned, eventhough that would put strain on your tonal quality already. Nonetheless, if you tune to G, you should use a .070, if you have a standard "25.5-scale.
Old 01-21-2008, 05:30 PM
It's a Dean Evo 7 (if I can actually get it) and I'm unsure of the scale.
Old 01-21-2008, 05:54 PM
Sigar  is offline
Posts: 107  -  iTrader: (0)
It's 25.5"
Old 01-21-2008, 08:04 PM
Of Angels  is offline
Posts: 516  -  iTrader: (8)
A .70 will work on a 25.5" scale if you tune it to G... if you want to go down to F or even sub-octave E on that short of a scale, use an .80 and you won't have problems with stability or tone... of course, the nut on that guitar would have to be cut to accommodate either of those strings... but from my experience, an .80 gauge actually sounds monstrous when tuned to F, rather than dead and flabby.
Old 01-22-2008, 12:40 AM
Lefty Robb  is offline
Is there a need to go that low, I know Devin does G and thats crazy low...
http://www.youtube.com/watch?v=aQaZQ...eature=related
Old 01-22-2008, 11:17 AM
jim777  is offline
At F why not just get a bass or a sampler?
Old 01-22-2008, 11:36 AM
varador  is offline
Posts: 116  -  iTrader: (0)
+1 yeah dude if you like downtuning so much, just get a bass... drop F... jesus, what the hell for?
Old 01-22-2008, 01:21 PM
To be brutal, duh.
Besides - if he gets a bass, he'll still need another dude to have a bass tuned an octave lower. I still haven't figure out how that's possible, but oh well.
My drummer and I play that low just to dick around sometimes... it's kinda fun, haha.
Old 01-22-2008, 03:01 PM
Variant  is offline
Posts: 76  -  iTrader: (0)
Originally Posted by Of Angels View Post
To be brutal, duh.
Long scale would help here (think RG1077XL or ESP Stef 7), though I used to go drop-G with a .070 on my RG7620 (25.5"). While it worked and the string tension was fine, your real hurdle is will likely be the pickups. The result will almost surely be some combination of muddy and boomy no matter how you EQ things. Personally, I'd reccomend a switch to an EMG or Lundgren in the bridge before doing anything that low.
As for the bass: Subcontra tunings, while not very common, are entirely possible (hey, the Warwick Dark Lord comes in F#0). Again, good (active, IMHO) pickups are a big part of the solution here, and a massive single string for the lowest notes. My bass is tuned one octave below my RG2228 eight string (which one step down to E1), to E0... about 20 hertz. :-)
Old 01-23-2008, 05:04 PM
partyonpat  is offline
Posts: 19  -  iTrader: (0)
i play gcgfea on a esp ltd-1000 and it's fine, you just have to get the right strings
Old 01-24-2008, 06:16 AM
Karl Hungus  is offline
Posts: 148  -  iTrader: (0)
It's a guitar, with guitar pickups, and going through a guitar amp. It's not going to sound like a bass, even at that kind of tuning, and the point of downtuning is not to replicate a bass.
So honestly, telling someone to just get a bass is maddeningly unhelpful.
Old 01-26-2008, 07:08 PM
p4vl  is offline
Posts: 17  -  iTrader: (0)
Question
I'm confused. Some of you are willing to use guitars with an additional string and pay extra for custom finishes and special hardware, but you think that tuning it really low is too unorthodox? Why stop with standard tuning+1 or dropped D+1?
baritone guitar, dean evo, neck scale, string bass, string tension
Seting up an RG for B tuning - String Gauge? fyrie Tech: Setup, Repairs and Mods 15 11-08-2005 03:57 PM
Tuning Down and String Guages slugman Tech: Setup, Repairs and Mods 7 09-06-2005 06:08 PM
Tuning to drop D? DT Erotomaniac Other Ibanez Guitars (including Premiums) 6 07-13-2003 05:45 PM
7 string tunigs christianc Other 7-string Guitars 20 10-11-2002 02:18 PM
Drop D Tuning pigdestroyer Tech: Setup, Repairs and Mods 2 08-13-2002 03:03 PM
