Old 08-18-2006, 03:25 AM
Aris_T  is offline
Posts: 597  -  iTrader: (0)
Fernandes 7 string baritone
What do you think of this?
http://www.fernandesguitars.com/rl7b.html
Doesn't it look great?
Old 08-18-2006, 08:32 AM
HoP  is offline
Posts: 143  -  iTrader: (0)
Re: Fernandes 7 string baritone
fugly
Old 08-18-2006, 08:35 AM
Lefty Robb  is offline
Originally Posted by HoP View Post
fugly
like all Fernandes...
Old 08-18-2006, 09:38 AM
eelblack2  is offline
Posts: 865  -  iTrader: (4)
I like it. Im schocked to see EMG's in there stock. I have one of the older Revolver 7's with the sustainer and its a great guitar.
Old 08-18-2006, 11:17 AM
Awakened Sleeper  is offline
Posts: 203  -  iTrader: (2)
Apart from the hideous headstock I like it too. A 27" scale, EMGs, neck-thru, offset dots, & matt black finish makes it a winner in my book. Probably mega-expensive with the limited production run though. Hmmm, a quick Google found one priced at $999, not TOO bad.
Old 08-18-2006, 05:05 PM
Demiurge  is offline
Posts: 883  -  iTrader: (7)
Not terribly competitive price point, considering you can get an identically-spec'd (and similarly styled) Schecter for less. If they price it at a grand, they should have a Sustainer on it if they wanted to set it apart and make it worth the extra money.
Old 08-18-2006, 06:09 PM
technomancer  is offline
Posts: 663  -  iTrader: (6)
You did catch that it's a limited run of 36 instruments, right? Taking that into account it's a LOT cheaper than I would have expceted.
Old 08-18-2006, 11:03 PM
Flobanez  is offline
Posts: 5,513  -  iTrader: (1)
It's alright, I've seen worse, although im not a fan of the finish, it looks like a decent 7. I'd play it.
Old 08-18-2006, 11:10 PM
bonehead189  is offline
Posts: 537  -  iTrader: (0)
Sure is, I also read the fine print. "Only 36 pieces made!"
Old 08-19-2006, 02:30 AM
thadood  is offline
Posts: 90  -  iTrader: (0)
Wouldn't be bad with a dfferent headstock and some Seymour or Dimarzio's in it. I like the flat black look..
Old 08-19-2006, 02:58 AM
So what exactly is the tuning on a 7 string baritone? I mean, is this thing so low that you would almost need a bass amp to properly amplify it without it sounding like ass? Having that low B go down a whole 5th seems ludicrous to me. I know Vai has one, but he doesn't seem to use it much at all.
Old 08-19-2006, 09:45 AM
NeglectedField  is offline
Posts: 945  -  iTrader: (0)
No they're tuned the same as regular 7s, the extended scale is just for extra tension so that the low B has the same piano-like clarity as it does on a baritone.
Old 08-19-2006, 03:21 PM
Demiurge  is offline
Oops, guess I missed that part. That said, it makes even less sense- limited run of an instrument with what will probably become a more popular feature set for a 7-string (extended scale, EMG's) that's STILL more expensive than its direct competitor but not expensive enough to benefit their bottom line on a limited-run instrument. Maybe if they made more than 36, they could charge less. Furthermore, if rarity is ever a greater selling point than the instrument itself- it's meant for collectors, not players. Uniqueness may prove to be an exception, but Schecter's making the same freaking thing right now!
Old 08-19-2006, 06:57 PM
Then the word baritone seems like a very misleading word when it comes to these 7 strings if they hold the same tuning. So really any 7 string with a 27" scale is actually a baritone (such as that Agile)
Old 08-20-2006, 05:00 AM
ry4n  is offline
Posts: 47  -  iTrader: (0)
i think they only made 36 cause they'll only sell 28
lol
baritone guitar, bass amp
Yet another poorly mixed song by your truly IbanezroadstarII Multimedia: Music, Pictures & Sounds 33 03-16-2006 10:01 PM
8 string baritone theagentorange Tech: Setup, Repairs and Mods 4 08-22-2005 08:16 PM
tuning a seven string baritone "normal" skattabrain Other 7-string Guitars 9 11-12-2004 05:34 PM
strings for my new 7 string baritone (1077xl) skattabrain Other 7-string Guitars 5 11-06-2004 03:17 PM
Fatty-My 7 string baritone hollowbody ATDVSBL Other 7-string Guitars 19 06-22-2003 04:09 AM
