Other 7-string Guitars
"From scratch" custom-shops?
7-string, 8-string & extend-range guitars guitar talk only here. All makes and models except the Universe.
03-14-2006, 02:43 PM
Roland
Posts: 617 - iTrader: (
Hey there. I'm currently testing the waters on what my 8-string
fanned fret
design would go for, so I'm asking anyone if you know what custom-shops would take an order for a completely
custom guitar
Here is the design, by the way.
http://img369.imageshack.us/img369/4...edfret81vg.jpg
Already know of Conklin (too expensive), and mailed LGM (they don't take custom guitar orders anymore)
Roland
Find all posts by Roland
03-14-2006, 02:55 PM
fettouhi
Posts: 9,937 - iTrader: (
Re: "From scratch" custom-shops?
Roland
Hey there. I'm currently testing the waters on what my 8-string fanned fret design would go for, so I'm asking anyone if you know what custom-shops would take an order for a completely custom guitar.
Try
Christopher Woods
Regards
André
fettouhi
Find all posts by fettouhi
03-14-2006, 05:28 PM
littlegreenman
Posts: 2,626 - iTrader: (
As far as I know, Conklin is about the only company that has permission to use the fanned fret (novak) system, so they're probably your best bet. I have a couple customers who are waiting on guitars from them, but as you noted, they are pricey, one of my customers is going on 3 years now for his guitar from them as well. As hard as I have tried to be quick in getting stuff finished for people, something is always coming up that slows things down, that coupled with a year of bad time management (entirely my fault) has me way behind schedule, hence the no custom orders right now. But no matter who you go with, be prepared to wait, hopefully in the end it will be worth it
Jeremy
I should reword my comment about conklin and the fanned fret system. As far as I know, they are the only company in north america consistently doing the fanned fret system commercially (other than novak). You must pay royalties as well as be accepted by novak to do the fanned fret system. Those are a couple of the reasons I don't use the fanned fret system.
littlegreenman
Visit littlegreenman's homepage!
Find all posts by littlegreenman
03-14-2006, 05:41 PM
gitarguy
Posts: 377 - iTrader: (
fettouhi
Try Christopher Woods.
Regards
André
Christopher isn't taking orders right now and the wait time for his work is really really looong.
gitarguy
Find all posts by gitarguy
03-14-2006, 05:44 PM
Roland
When you're picking up the custom orders again, will you be building fanned fret instruments as well if they're included as a spec in the order, Jeremy?
Roland
03-15-2006, 09:37 AM
Aris_T
Posts: 597 - iTrader: (
Try
http://www.nevbornguitars.com
. Don't know if he makes guitars from scratch but you lose nothing by e-mailing him.
Aris_T
Find all posts by Aris_T
03-15-2006, 04:46 PM
Demiurge
Posts: 883 - iTrader: (
FWIW, Novax actually sells an 8-string fanned-
fret neck
and bridge, so all you'd need to do is have someone make a body (routed to slightly different specs), so that would increase the # of shops you could talk to. Only drawback, though, is that the neck alone is extremely expensive and the headstock is drilled for bass tuners for the lower 3 strings (because it's "
Charlie Hunter
" style).
Demiurge
Find all posts by Demiurge
03-25-2006, 05:44 PM
Jim Soloway
Posts: 518 - iTrader: (
littlegreenman
As far as I know, Conklin is about the only company that has permission to use the fanned fret (novak) system, so they're probably your best bet. ...
Dave Wendler from electroCoustic has done a few fanned fretboards and I know that Saul Koll is working on one. They are paying royalties to Novax.
Given the custom fabrications and the royalties, a guitar built from this design would have to be pricey no matter who built it. Even buying the 8-string neck and bridge from Novax, you'd be in for $1860 befor you started building the guitar itself.
I've taken a second look at this design. Assuming it could actually work (I think the scale length differential is probably too small), my guess is that anyone who's talented enough to build it would proabably charge a minimum of $4500, probably more.
06:29 PM
Jim Soloway
Visit Jim Soloway's homepage!
Find all posts by Jim Soloway
03-26-2006, 04:04 AM
fettouhi
Wow that much for the neck and bridge alone! What's the benefit of having
fanned frets
Regards
André
fettouhi
03-26-2006, 11:12 AM
Roland
fettouhi
Wow that much for the neck and bridge alone! What's the benefit of having fanned frets?
Regards
André
Differing
string tension
Roland
03-27-2006, 01:09 PM
Demiurge
fettouhi
Regards
André
There's a pretty big dissertation on the idea behind fanned frets on the Novax website. Not sure how much of it is metaphysical buggity-boo, but it sounds neat. The Charlie Hunter guitar is more of a hybrid than an extended-range guitar because of the separate string types (the bass side uses tape-
wound strings
) and pickups for each set of strings, but it could be finagled in some way.
As silly as it sounds, I've been tempted to buy a cheap six-
string bass
, swap out the bridge, pickups, do a fill-and-drill on the headstock and viola- 8-string guitar! The nut and bridge widths are similar, but the 34" scale (not to mention the funky fretting on the higher frets with the fretboard tapering) may be a bit cumbersome. Probably wouldn't work, but I'd love to experiment. I have a 30" six-string that goes down to a low G on a .058 alright and my hands are big enough to fret on it, so I'm curious.....
Demiurge
03-27-2006, 01:23 PM
fettouhi
Demiurge
Don't remind me about dissertation I'm handing my in on Friday
Regards
André
fettouhi
03-28-2006, 12:05 AM
frankfalbo
Posts: 1,875 - iTrader: (
Jim Soloway
I've taken a second look at this design. Assuming it could actually work (I think the scale length differential is probably too small), my guess is that anyone who's talented enough to build it would probably charge a minimum of $4500, probably more.
Any scale differential "works" as a fan fret, it's just a matter of the degree of benefit. I think starting at 28" may be too long for the treble side, but that's just my opinion. It's a simple enough design that I could do it for more like $3000, but yes, it would take me a long time too. Plus besides enhancing the quilt top, I would farm out the finish.
frankfalbo
Find all posts by frankfalbo
03-28-2006, 07:12 AM
Jim Soloway
frankfalbo
Have you built a guitar with a fanned fretboard yet? If so I'm curious what you used for a bridge?
Jim Soloway
03-28-2006, 11:17 AM
Roland
How about a custom hardtail? Like the regular Ibanez hardtail RG's, but where each saddle sits on its own small metal plate, which you can then put in whatever intervals you like.
Roland
bridge saddles
charlie hunter
christopher woods
custom guitar
fanned fret
fanned frets
fret guitar
fret neck
fret necks
guitar shop
string bass
string tension
wound strings
show your j custom
where can i buy a richie kotzen custom ibanez
where is sims custom shop address
where to get j.custom ibanez gakki
where is the ibanez japan custom shop
'Custom' Ibanez
Shredder stuck in the 80s
05-16-2007
03:01 PM
FS : ibanez RG USA CUSTOM 1991 UCEW1FM
fredperry
06:00 PM
blaze custom vs custom 7 (also called NEW 7)
ibanez7addict
11:04 PM
Custom shops/online custom builders?
Clydefrog
06:01 PM
03:54 PM
