I've had the same problem, with the same response. I just haven't come around to do it yet. I guess its because I can still use the guitar the way it is. Also, I'm switching the pickup to a
Dean EVO to see if it fits better.
I'd try clipping the ends of the screws, maybe cut them with a dremel tool. It would be best to trim the minimal ammount of the screws if you decide to try it.
Post if it works, hope this helps
