Old 01-03-2008, 10:31 PM
Codyyy  is offline
Posts: 68  -  iTrader: (0)
I am in need of a 7 string...
Here's the deal. I have about $1200. I want to get the best possible 7 for my money, period. I was originally and am still considering a custom Carvin, but I've heard so many bad things about their pickups, and in my mind, one shouldn't have to upgrade the pickups in a "custom" guitar.
So, in your opinion of course, what is the best NEW 7 string for at/under $1200? Unfortunately, the RG1527 seems to fall under the same category as the Carvin, bad pickups... maybe Ibanez is even ruled out because of this, I don't know!
HALPZ?
Old 01-03-2008, 10:36 PM
Andelusion  is offline
Posts: 1,373  -  iTrader: (4)
Re: I am in need of a 7 string...
If the Carvin is right for you then you should definately NOT let the niggle of pickups put you off, the pups can be upgraded really cheaply if you go second hand.
The option to build a guitar with what woods you want for so cheap (Carvin) is something that you can't really forget about so easily in my opinion.
Old 01-03-2008, 10:44 PM
elcid  is online
Posts: 8,718  -  iTrader: (12)
Save more money and get an EB/MM JP7 or a Universe.
Old 01-03-2008, 10:46 PM
Drow Swordsman  is offline
Posts: 741  -  iTrader: (2)
Used UV's can generally be had for right around your price range, $1000-1200.
Codyyy  is offline
See that's where the interesting part comes in. If I had the money for a JP7, I would also have the money for a Carvin with really nice pickups in it.
Old 01-03-2008, 10:48 PM
jim777  is offline
You won't get a loaded Carvin for $1200, never mind having cash left over for replacement pickups. That said, the pickups sound much worse in the standard maple neck/alder body config than they do in mahogany neck/mahogany body with maple top. I bought a Blaze/Blaze Custom combo to go in my 727 but I haven't gotten around to it after nearly 2 years because the stockers sound fine (if not fantastic) with the right wood combination.
With 1200, I would look for a 1527 and some toys like an X3 Live. You could get a used Carvin, but for 300 more you could get your custom Carvin, which I think is a better option than going used.
Old 01-03-2008, 10:50 PM
elcid  is online
Pickups can always be changed later, but that being said I have heard the complete opposite. I've heard that Carvin's pickups sound best with the standard body woods and if you start to change that the pickups arent as nice. Of course I have a friend who was at Carvins showroom and after seeing and playing those he swore to never buy a Carvin ever. I guess the point is everyone you ask can give you a different answer.
Old 01-03-2008, 10:51 PM
Codyyy  is offline
With 1200, I would look for a 1527 and some toys at an X3 Live. You could get a used Carvin, but for 300 more you could get your custom Carvin, which I think is a better option than going used.
I guess whatever 'loaded' means to you...
ASH - Maple Neck/Swamp Ash Body $40.00
-CG - Clear Gloss Finish (Standard) $0.00
FTR - Crimson Red Flame $160.00
FPH - Flamed Maple Headstock $25.00
BMF - Birdseye Maple Fingerboard $30.00
-DI - Dot Inlays (Standard) $0.00
STJF - Stainless Jumbo Frets .055" H .110" W $40.00
-R14 - 14in Fretboard Radius (Standard) $0.00
-C26B - C26 Bridge Pickup $0.00
-C26N - C26 Neck Pickup $0.00
-400 - Black Coils w/ Black Bezels (Standard) $0.00
-CH - Chrome Hardware (Standard) $0.00
-1056 - Elixer Light Gauge .010 - .056 (Standard) $0.00
WL - White Logo $0.00
HC11 - Form-Fitted ABS Hardshell Case $49.00
Guitar Total: $1,173.00
Old 01-03-2008, 10:53 PM
jim777  is offline
Loaded definitely means not getting the maple neck alder body combination, as I already mentioned. Skip the maple neck. The swamp ash is also going to be a bit bright. Carvins are naturally bright, you should aim to subdue that.
Old 01-03-2008, 11:00 PM
Codyyy  is offline
Ah, gotcha. Well, either way, I definitely want to keep my options open. Carvin, or not.
Old 01-03-2008, 11:18 PM
Codyyy  is offline
The JP is clearly awesome but if I ordered one I would have to wait an estimated twice the amount of time I'd wait for a Carvin, so I would need to know some dealers.
Also, this may be the wrong place to ask but... isn't $1500 a little much to be spending on a basswood guitar?
Old 01-03-2008, 11:22 PM
jaxadam  is offline
Classified Watchdog
Posts: 3,042  -  iTrader: (9)
I will echo what Jim said and start with a 1527 and do a pickup change.
Old 01-03-2008, 11:23 PM
jim777  is offline
Nothing at all wrong with basswood. Tom Anderson puts basswood with a maple top as the ultimate tone body. It's usually a bit cheaper than other woods, but rarity and availability don't necessarily equate to quality. I happen to like it, though I do like mahogany more.
Old 01-03-2008, 11:24 PM
jaxadam  is offline
Classified Watchdog
I will also echo that there is nothing wrong with basswood, and I sometimes think it gets a bad reputation.
Old 01-03-2008, 11:25 PM
jim777  is offline
Their 6 string pickups are great pickups any way you look at them. I moved up to Carvin singles in my Mexi Strat and they're a big improvement in that guitar. Their 7 string pickups however aren't so lucky
Eight string finished..... Serratus Other 7-string Guitars 62 10-05-2006 05:38 PM
String bending (low action) blackpuppets Tech: Setup, Repairs and Mods 12 10-27-2005 03:56 PM
Bass pickups in 7 string and 7 string single coil demo juiceofvenus Pickups & wiring 4 08-29-2003 03:54 PM
D string refuses to intonate illumina Tech: Setup, Repairs and Mods 0 08-01-2003 03:32 PM
Picking up the slack... - ...on that low string mechanyx Tech: Setup, Repairs and Mods 7 03-31-2002 02:23 AM
